Firmware 10 on System Red PCB 10.5 - firmware bug ???
I installed the new firmware on my PCB 10.5 controller for System red. The PCB was manufactured according to schematic and Eagle-File:https://docs.lightningmaps.org/files/hardware/red/PCB_10_5.brd
The firmware did not work properly as the PCB-ID was not detectected correctly. It turned out that PCB 10.5 has a different coding then described.
Description according to the hardware reference in TablePCB Controller Ids:
 https://docs.lightningmaps.org/hardware/...system-red
Id PCB System PD10 PD11 PD3 PD1 Offset
2 10.5   RED      -        +        -       -      0
but it turned out that actually Coding of PCB 10.4 and PCB 10.5 is different, PCB10.5 has the following coding:
? 10.5  RED      +        +        -       -       0
this can also be seen in the schematic of PCB 10.5,  so PD10 has a high level +5V  instead of GND like PCB 10.4.
I did cut off pin PD10 from the controller-board and now all is working; PCB 10.5 is detected as PCB10.4 now
... but it seems that there is a firmware bug in 10 RED ???? This potentially could affect several stations, as station list has decreased since new firmware is out
  Uploading Firmware! Please wait... Tecsol 2 15,785 2018-02-03, 17:17
Last Post: Mark.Smith
  Problem after updating firmware. blue 8.32b readbueno 30 144,080 2017-09-11, 23:51
Last Post: readbueno
  Updated firmware to 8.0 (RED) and station stopped working properly Geewizard 2 16,864 2016-08-28, 13:33
Last Post: Geewizard
  Why firmware is not open-source? EugeneF 2 20,250 2014-08-10, 23:24
