Newbie question
I would like to know if you can use a bolted lightning detector and if not can you tell me if you can get your equipment pre-built
(2018-01-23, 01:19)Hkibler Wrote: I would like to know if you can use a bolted lightning detector and if not can you tell me if you can get your equipment pre-built
No Boltek is a different system.
For the second part of your question, please see:
https://docs.google.com/document/d/1KzPZ...1516672436
There is some assembly required.  This is NOT a 'Plug and Play" system... much more is involved than just turning it on.
"...primarily aimed to individuals with an interest in meteorology and competencies in electrical and computer engineering. For the construction and operation of a lightning detector a basic understanding of the used reception technique is necessary."http://en.blitzortung.org/cover_your_area.php
  Newbie wants to contact a nearby Member Moonbouncer 4 42,016 2018-10-29, 00:08
  I'm a newbie stevewhite257 2 25,819 2018-05-27, 23:31
Last Post: allsorts
