Looking to setup station in South Africa
#41
(2015-06-19, 07:38)Knickohr Wrote: You sending a lot of disturbers :
Whats this ?  An electric fence ?
Thomas
Hi Thomas,
Not sure what that is.
I actually have much larger disturbers as well. I'll try turn down the gain manually - let's see what happens, my station might go totally quiet then Undecided
If I don't have too much success with this station I could consider installation at another location down in the Eastern Cape along the coast, I might have better success down there...
Roger
Stations: 1352
#42
That doesn't help !
You only separate the disturbers, not the strokes Wink
Try to locate it, try shielding the ferrite. Try to find a sweet spot, maybe rotating the antennas work.
Thomas
Stations: 1006, 1305
#43
(2015-06-19, 07:38)Knickohr Wrote: Whats this ?  An electric fence ?
Thomas
Since both singals are in phase and in the same polarisation, possibly it's coming via the power supply / mains. You can turn one antenna 180°. If it persists, you need to put a choke between the controller and the psu.
I had the same problem here, my 230V-line is very noisy and the PSU does not decouple these frequencies.
Stations: 233
#44
(2014-12-05, 07:37)rogerpaulthompson Wrote: Hi all,
I'm interested in setting up a station in South Africa and wondered if there are any other potential users out there in South Africa looking to setup a station.
I am located in Pretoria at approximately -25.849041°, 28.228571° and am looking to hear from you !
Roger
Hi Roger
I am Louw and would like to do the same. I am in Port Elizabeth. I have tried to get one of the new green I think its called receivers but
haven't heard a thing from them. I would like to hear from you if you get info from them.
Louw. If you want to contact me use this e-mail:ferreirasl@telkomsa.net
#45
I have a pre-assembled system Red for sale to any South African. Includes both amplifiers and an H-field antenna.
Stations: 1332
#46
(2016-03-01, 13:38)Jacquesvw Wrote: Hi,
Hi Jacques.
Sure, Ill take it. I'll PM you ...
Roger
Stations: 1352
  Proposed New Blitzortung Station in Regional South Australia JohnCappello 2 5,683 2026-01-13, 23:26
Last Post: dupreezd
  New Station in South Australia NickInOz 1 5,764 2025-12-11, 16:47
  Africa joseph.uzoagba@alphamead.com 14 69,667 2025-11-25, 07:11
Last Post: MDuperrier
  Lightning strikes displayed in South Africa GBeS29 3 40,848 2021-11-05, 09:31
Last Post: devilmaycry
  South East Asia possibilties Dan 0 11,778 2021-10-02, 11:43
Last Post: Dan
