Issue starting Sunday August 1st at 13.00
Gents,
I noticed that my receiver was working not as it should and suspected to find a technical issue here at home.
Looking into it, I could not find any and checked some other stations and found the same issue. So it must be a mutual problem.
It seems that from Sunday, August 1st around 13.00, something is going wrong. When I look at the list of stations in eg the Netherlands, I see the same issue starting at the same time. The number of detections dropping suddenly and the same color pattern in the image.
As example I added images from myself (1152) and from 1271; you can clearly see same pattern and start of disturbance.
Something going on in the collective system?
Frank Veldhuijsen
Update Sat. August 7th, 11:26 UTC
Received E-mail from Egon that he is working on the issue.
(2021-08-07, 11:27)PA4EME Wrote: Update Sat. August 7th, 11:26 UTC
And has fixed the problem, back up again for a few hours Smile
Stations: 2041
  Strange goings on - started at 00:00 Oct 30 2022 mzseast 19 71,957 2022-10-31, 17:09
Information System Blue Order Status 12. August 2016 Egon 435 4,625,930 2019-12-31, 17:39
Last Post: mwaters
  Firmware issue (8.0 RED) Geewizard 5 49,659 2016-08-27, 14:12
Last Post: Geewizard
  network cable connection issue orion_jb2001 3 36,738 2015-02-17, 12:24
Last Post: seemakm
Users browsing this thread:
