Desensitizing Effect of TOA System - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30) +--- Thread: Desensitizing Effect of TOA System (/showthread.php?tid=401) |
Desensitizing Effect of TOA System - Kalamara - 2014-03-16 I have been experimenting with the lightning strikes and the gain factor of antenna and preamp. When the gain is set a little to high with consideration to the antenna being too high in receive performance we have desensitizing effect. An auto gain feature would work well . As I discovered the newest TOA board that has come out version 10 I saw spoke of an auto gain feature. This I guess addresses the issue I have found. I have designed my antenna as a 2-foot pvc loop antenna with 25 turns, 22gauge stranded wire and gain set at preamp of 43x Gain. Channel A,B jumper set on pin 2. The preamp board is PCB 5 version 7, Data board PCB 6 version 8. Are there any newer preamp board versions available?? Please let me know. I will be looking into an auto gain method. Or finding a setting that fits both distance and local strikes which will give best effciencies at 5000km and moderate level efficiencies. The best we can do is use a gain that will fit most instances of nearby high activity storms as well as distance ones. Or find a way to build an auto gain preamp. Paul |
