Documentation - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: General Discussion (https://forum.blitzortung.org/forumdisplay.php?fid=31) +--- Thread: Documentation (/showthread.php?tid=3993) |
Documentation - Tobi - 2025-01-18 The project documentation can be found here: https://docs.lightningmaps.org Since 2024 most of the information from different PDF files, Compendium, Wiki, forum threads are combined there. If you think that some information should be added to the documentation then just use this thread here. Contributing The documentation is made with Mkdocs which is based on simple Markdown files. The source of the documentation consists of two git repositories which are available here: https://gitlab.lightningmaps.org/common/docs https://gitlab.lightningmaps.org/common/bo_files It may also be cloned to github in the future or when someone requests it. |
