RJ45 Network - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30) +--- Thread: RJ45 Network (/showthread.php?tid=2551) |
RJ45 Network - Alanpenwith - 2018-03-30 Hi All A bit of a continuation of my Lost Controller thread. As someone suggested the Vonets wifi connection I thought I would try it. It's a much neater unit than the old access point I got working. I managed the get the router to see the controller's IP but I can't get a connection through the browser. Also the network led pulses. Looking closely the Vonet rj45 plug seems only to have pins 2 and 3 connected. So what are the pins used by the controller RJ45 network socket ? Regards Alan RE: RJ45 Network - dupreezd - 2018-03-30 (2018-03-30, 16:47)Alanpenwith Wrote: Hi All At a MINIMUM, an ethernet RJ45 needs pins 1,2,3 and 6. RE: RJ45 Network - mwaters - 2018-03-30 Here you go, Alan. https://goo.gl/images/qv0V5A
RE: RJ45 Network - tassyjim - 2018-03-31 What model Vonets device do you have. My VAP11G certainly has the required 4 wires connected. pin 1 brown pin 2 orange pin 3 green pin 6 white Look at the end, the wires are often easier to see end-on. Jim RE: RJ45 Network - Alanpenwith - 2018-04-02 (2018-03-31, 23:23)tassyjim Wrote: What model Vonets device do you have. My VAP11G certainly has the required 4 wires connected. Thanks It is VAP11G 300 but only 2 and 3 are obviously coloured the rest are black although looking at the ends there seem to be wires to 1 and 6 - the others don't appear to have wire cores they look like just solid plastic. I don't find the instructions very clear so experiments look like the answer. Regards Alan RE: RJ45 Network - tassyjim - 2018-04-03 Test the Vonets with your PC. Turn off the PC WiFi set your PC's Ethernet to "Obtain IP automatically" Connect the Vonets to the PC's Ethernet port. Check that you have internet access. Jim |
