Select station - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Website, Maps and Applications (https://forum.blitzortung.org/forumdisplay.php?fid=24) +--- Thread: Select station (/showthread.php?tid=2259) |
Select station - pnavoy - 2017-08-06 Hello, I will ask you for more experienced advice. I installed MyBlitzortung PHP. The program displays my map but no station selection is possible, and when I try to update it displays the following information. 2017-08-06 12:02:56 + 0ms | 2017-08-06 12:02:56 + 0ms | ***** Getting lightning data from blitzortung.org ***** 2017-08-06 12:02:56 + 0ms | 2017-08-06 12:02:56 + 2ms | Information: PHP Execution timeout is 60s -> Fine ![]() 2017-08-06 12:02:56 + 3ms | Waiting 1 sec, to avoid too high load on Blitzortung servers ... 2017-08-06 12:02:56 + 1006ms | 2017-08-06 12:02:56 + 1006ms | === Strikes === 2017-08-06 12:02:56 + 1012ms | Last strike: 2017-08-06 11:10:00 *** Loading 6 files from 2017-08-06 11:10:00 to 2017-08-06 12:00:00 *** This is update # 6 2017-08-06 12:02:56 + 12318ms | Downloading file /2017/08/06/11/10.log, last position 0 bytes: OK 2017-08-06 12:02:56 + 12318ms | Found latest strike from last import 2017-08-06 12:02:56 + 26840ms Downloading file /2017/08/06/11/20.log: OK 2017-08-06 12:02:56 + 40439ms | Downloading file /2017/08/06/11/30.log: OK 2017-08-06 12:02:56 + 54719ms | Downloading file /2017/08/06/11/40.log: OK 2017-08-06 12:02:56 + 54722ms | TIMEOUT! We will continue the next time. 2017-08-06 12:02:56 + 54722ms | Lines: 10551 *** Size: 4315kB *** New Strikes: 10550 2017-08-06 12:02:56 + 54755ms | TIMEOUT: Continue next time ... 2017-08-06 12:02:56 + 54757ms | 2017-08-06 12:02:56 + 54757ms | Import completed. Exiting ... 2017-08-06 12:02:56 + 54757ms | I do not know where there might be a mistake. This message is always displayed. The designation of my station is 1926. Thank you for your advice. Navoy RE: Select station - allsorts - 2017-08-06 Have you entered your station details into the config.php file located in the base directory of your MyBlitzorgtung installation? |
