Time change - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: General Discussion (https://forum.blitzortung.org/forumdisplay.php?fid=31) +--- Thread: Time change (/showthread.php?tid=2257) |
Time change - ohifra - 2017-08-01 Good evening, I can not find the menu where to change the time from UTC to Europe / Rome in the blue system. Many thanks in advance Francesco RE: Time change - kevinmcc - 2017-08-02 I do not believe there is a setting you can change. RE: Time change - ohifra - 2017-08-02 (2017-08-02, 02:13)kevinmcc Wrote: I do not believe there is a setting you can change. ok thanks
RE: Time change - Andrew.Instone-Cowie - 2017-08-02 Time is always UTC, I think. Andrew |
