Offset adjustment - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30) +--- Thread: Offset adjustment (/showthread.php?tid=2199) |
Offset adjustment - radiofarol - 2017-06-11 Does someone tell me why the system graphic of my detector show always a offset of + 50/60mV from zero? Can I adjust this anywhere? In the web interface, a can`t find any adjustment for this! It`s seem any wrong value in the ADC. ![]()
ST ID 1846 RE: Offset adjustment - kevinmcc - 2017-06-12 That is normal. There is a slight DC component that causes the offset. Not adjustment is needed, and why there is no option. RE: Offset adjustment - radiofarol - 2017-06-12 Tanks a lot lot Kevin for your reply. I understanding that is a sliht DC component. I was a bit worried that this offset would change the results of the system, but if Kevin says it's normal, I'll be calmer. Thanks again! Best 73 Carlos CT4RK STID 1846 RE: Offset adjustment - DanielVe - 2017-07-24 Hello, When I started my station I noticed the same issue. Finally I cleaned all PCB with Kontakt WL product and all DC components have disappeared. Best regards Daniel / ON4LDZ RE: Offset adjustment - allsorts - 2017-07-25 Oooo, that's interesting. Now what is "Kontakt WL"? A residue free, volatile, cleaner. Finds the safety data sheet, mostly isopropanol (propan-2-ol, isopropyl alcohol) with a dash of light petroleum (Naptha, lighter fluid). Have both of those lying about... Did you just clean a few selected areas or give the whole board, both sides, a good squirting with Kontackt WL? |
