System RED with off the shelf Atmegas - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30) +--- Thread: System RED with off the shelf Atmegas (/showthread.php?tid=2041) |
System RED with off the shelf Atmegas - Drayton - 2016-11-29 Hi Last night I finally got around assembling the System RED that has been sitting on my shelf for a very long time now. (Really sorry about that. Reason: children) The Atmega8's are off the shelf (not kit ones) and I'm guessing that they have to be programmed but I cannot find any information about this in the documentation or in the forum? RE: System RED with off the shelf Atmegas - DelandeC - 2016-11-30 Hello, You'll the firmware at http://fr.blitzortung.org/Compendium/Firmware/ ![]() Don't forget to read Red_PCB_12_PCB_13_ATMEGA_info.txt. RE: System RED with off the shelf Atmegas - Drayton - 2016-11-30 Thank you. I see that the latest fw there is 1.7, but trough a little googling yesterday I found 1.8. I was lacking the fuse info, very helpful! RE: System RED with off the shelf Atmegas - DelandeC - 2016-11-30 1.8 is for system BLUE. For system RED use one of those: Red_PCB_12_PCB_13_ATMEGA-48_1.6.hex Red_PCB_12_PCB_13_ATMEGA-48_1.7.hex Red_PCB_12_PCB_13_ATMEGA-8_1.6.hex Red_PCB_12_PCB_13_ATMEGA-8_1.7.hex Depending if you have Atmega48 or Atmega8. V1.7 also handles E-Field amplifier. RE: System RED with off the shelf Atmegas - Drayton - 2016-12-01 Got both amps flashed with 1.7 and the correct fuse settings, works perfectly now! Ready to go online, just waiting for an account. Thanks again. |
