Install OpenWRT & XLT Tracker on ASUS WL-520GU router - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30) +--- Thread: Install OpenWRT & XLT Tracker on ASUS WL-520GU router (/showthread.php?tid=1589) |
Install OpenWRT & XLT Tracker on ASUS WL-520GU router - Geert - 2015-11-10 Hi, I like to send my thin-client on retirement after years of service and replace it with an OpenWRT running router that runs Blitzortung XLT Tracker on it. Are there any how to tutorials on this? I already found out that I have to use this OpenWRT build on the ASUS WL-520GU: Attitude Adjustment 12.09 openwrt-brcm47xx-squashfs.trx for the Also the FTDI drivers have to be installed: kmod-usb-serial-ftdi I have to figure this out how too. I need help on install and setup the XLT Tracker, so any info on this is welcome Thanks in advance for your input! |
