I need Help - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30) +--- Thread: I need Help (/showthread.php?tid=1524) |
I need Help - huberto - 2015-10-08 Hi my detector is pcb6 version 3. where i can find the drivers to connect to windws 7. i can not select a COM because it isnt reconoice by usb. Someone can help thankx RE: I need Help - DelandeC - 2015-10-09 Hello, I think PCB 6v3 has a serial connection So you'll to connect it to a RS232 (COM) port on your PC. On new computer there might be no COM port left so you need a Serial to USB converter (I use this one: http://www.digitus.info/en/products/accessories/adapter-and-converter/r-usb-serial-adapter-usb-20-da-70156/) RE: I need Help - huberto - 2015-10-09 thaks i will find tomorow one. RE: I need Help - huberto - 2015-10-09 i got a cable it is use serial on the detector and usb on trhe computer RE: I need Help - DelandeC - 2015-10-10 Is your problem solved? RE: I need Help - huberto - 2015-10-10 near... on the bord the light in red on, green on and the blue is flashing. The orange dont show.... i download the software serial tracker 6 and it is say RS232: COM2 open 115200 8, 1 N PASSWORD: verified RECIVER: No data please check your settings STATUS: NONE There isnt any manual? RE: I need Help - huberto - 2015-10-10 log file: Program closed 0000-00:00:00 Windows 7 0000-00:00:00 C:\..........\X86\serial_tracker.exe No new version available 0000 00 00 No input Program closed 0000-00:00:00 Windows 7 0000-00:00:00 C:\.........\X86\serial_tracker.exe No new version available 0000 00 00 No input Program closed RE: I need Help - huberto - 2015-10-10 ; Please don't change any value ; unless you know exactly what you are doing ; Delete this file to get the standards [Global] ApplicationName = WindowsTracker Version = WindowsTracker_6.20.2 © E. Korffmann 2015 [Start] Delay = 0 [Setting] Username = meteolasolana Password = ********** Verified = 2 Min = 0 Autostart = 1 Logfile = 1 GlobalSharedMemory = 1 Beep = 0 Timer adj. = 0 FirmwareVersion = - ; Critical Section, setting the wrong values will may stop your system Peak = 1.000000 [Serial] Port = COM6 Baud = 500000 GPS Baud = 4800 Data = 8 Stop = 1 Parity = N Handshake = 0 [GPS] GPS = 1 WAAS EGNOS = 0 [Monitor] X Value = 800 Y Value = 405 [Graph] Type = 1 [String] Space 1 = $ Space 2 = . Space 3 = $ Space 4 = $ [Screen] X = 1425 Y = 53 [Server] Region = 0 |
