Station Layer - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: General Discussion (https://forum.blitzortung.org/forumdisplay.php?fid=31) +--- Thread: Station Layer (/showthread.php?tid=1148) |
Station Layer - Gregory_J - 2015-03-04 Hello Station layer on blitzortung maps is not working. There is not showing stations on map. This is message for moderators of developers. Best Regards RE: Station Layer - cutty - 2015-03-04 (2015-03-04, 06:53)Gregory_J Wrote: HelloHi Gregory... I checked Lightningmaps.org, and Blitzortung.org for the 'real time' displays and the detecting stations layer seems to be working fine. Were those the maps you're speaking of? There are times as they update the server programs that there are issues, and a layer does not work properly... perhaps that was the case? Cheers! RE: Station Layer - Gregory_J - 2015-03-05 Maybe it was those reason, because today ( 5 march 2015) stations are working. Best Regards RE: Station Layer - Tobi - 2015-03-05 At least on Lightningmaps.org, there was a minor issue due a change in behaviour of the Google Maps API. RE: Station Layer - Gregory_J - 2015-03-10 If I can still pull subject of stations layer what means colors of stations green - working grey - offline I think yellow - red - |
