Possible design error for USB connector on PCB 22.2b
Bug
Hello! I am working on assembling some Mini-Blue systems, but I encountered an error when preparing the files for pick and place assembly.
It appears that the slot for the 4 thru-hole legs of the USB connector were not defined correctly, and they are being interpreted as 0.4mm holes instead of slots per the part diagram. I've checked with all of the major PCB fabs, and they all interpret the current 22.2b GERBER files as this way.
I was wondering if the owner of the PCB project files would be able to revise this and release a corrected revision on the public index, as this current version is incompatible with assembly of the USB connector.
[Image: p7mrMpR.png]
[Image: jJZeliR.png]
Users browsing this thread: 5 Guest(s)
