New station user, no forum access
Hi! I’ve just fired up my Blue basic, id 3228.
I did have this old forum account since before, but no Blitzorturtung account.
I created a new Blitzortung account from the linked page onboard the Blue basic.
However I didnt get any new forum account. Im not sure if I should have done it in another way?
Thanks for your support!
(4 hours ago)Henrik Wrote: Hi! I’ve just fired up my Blue basic, id 3228.
No, this account for forum will work... the forum does not cross reference to the Blitzortung database.
You're in Sweden?
Is your system active? I see your station 3228 not reporting --- appears to be configured as when originally tested, loaded, prior to shipping last year???... showing bad GPS.
You need to login to your station page at https://www.blitzortung.org/login.php make sure everything is correct, and 'anony' is ticked 'n'
Once you've checked the info, entered antenna configuration, etc... need to make sure station is operating, connected, etc. Note, your user name and password for Blitzortung may not be the same as the credentials you're using here...
