(2023-01-09, 12:42)cutty Wrote: (2023-01-09, 09:40)bogdan Wrote: Hi Mike,
I can't access that thread. I had the same GPS problem and I just updated the firmware to fix it, but I had to find that information elsewhere on the forum. Is there anything I need to do to get access to the thread you mentioned?
Thanks,
Bogdan
What's your station number?
I have two: 1918 and 2484.
Threads: 64
(2023-01-09, 13:57)bogdan Wrote: (2023-01-09, 12:42)cutty Wrote: (2023-01-09, 09:40)bogdan Wrote: Hi Mike,
Thanks,
Bogdan
Upgraded your access!
(2023-01-10, 22:54)cutty Wrote: (2023-01-09, 13:57)bogdan Wrote: (2023-01-09, 12:42)cutty Wrote: (2023-01-09, 09:40)bogdan Wrote: Hi Mike,
Thanks,
Bogdan
Thank you, it is working now!
(2023-01-12, 07:35)bogdan Wrote: (2023-01-10, 22:54)cutty Wrote: (2023-01-09, 13:57)bogdan Wrote: (2023-01-09, 12:42)cutty Wrote: (2023-01-09, 09:40)bogdan Wrote: Hi Mike,
Thanks,
Bogdan
Thank you, it is working now! May I ask that you also upgrade access for my station 1782.
Thank you!
T782
Threads: 0
(2023-01-14, 14:54)StuartS Wrote: (2023-01-12, 07:35)bogdan Wrote: (2023-01-10, 22:54)cutty Wrote: (2023-01-09, 13:57)bogdan Wrote: (2023-01-09, 12:42)cutty Wrote: What's your station number?
Thank you!
T782 Can I jump on the bandwagon as well and request my access to be upgraded as well station 1929
Threads: 7
to answer your headline question:
No.
i use the cheapest GPS stuff i can find. the "radio/decoder" side usually stops working long before the antennas do.
clean the connector with a contact cleaner. Ignore the OM Elmer advice to "just use whisky". IPA, at least 75%, will do.
GPS works indoors if you know where the wires and other metal in your house are.
It just needs a cone straight up to the sky to get a clear enough view of the sky;
maybe 30x30cm with only fiber and oil in the way.
I use an old pizza pan, put the magnetic GPS antenna in the middle.
Put that someplace where i get ~11ns absolute (0.1ns current) on gps fix
No issues with noname brand© gps antennas with the system blue i have. <3
Threads: 45
(2023-03-13, 05:31)genewitch Wrote: to answer your headline question:
By radio/decoder, does that mean your Blitzortung lightning receiver?
Threads: 0
Hello fellow users,
it seems that I have the same problem with my GPS reception. (Station 2947)
In the meantime I have tried another GPS antenna but without any result.
I tried to follow the link in this thread, but I am not authorized to do so. ???
Do I have to submit a request somewhere for that?
Thanks in advance for your response.
Kind regards,
Marcel
Threads: 11
(2025-05-13, 16:13)dutchcopper Wrote: Hello fellow users,
Kind regards,
Marcel
Hi Marcel, your profile was upped to participant and you should now be able to follow the links
(2025-05-13, 16:29)Eric.Wouters Wrote: (2025-05-13, 16:13)dutchcopper Wrote: Hello fellow users,
Kind regards,
Marcel
GPS issues (station 1479) and also not able to access the mentioned thread.
BR
/t
