If I purchase the BLUE SYSTEM and join blitzortung.org, what would be the lightning detection accuracy within a 10 km radius from the location where the device is installed? I imagine that the more detectors there are near the desired measurement location, the higher the accuracy will be.
Threads: 35
Quote:Your station best contributes to the computations if it is placed in a distance between 50 km and 300 km from the discharge. If the storm is nearby, your station usually overrides. Even a very low pre-discharge will cause a very high signal strength because of its low distance.
https://www.blitzortung.org/de/Compendiu...B_14.1.pdf
https://forum.blitzortung.org/showthread.php?tid=3880
Threads: 11
(2024-06-25, 01:33)eddistinct Wrote: I've been using the BLUE SYSTEM for a while now, and I can say that in areas with a dense network of detectors, the accuracy is excellent.
if you give us your station number, we will upgrade your status on this forum.
Threads: 0
Some android maps use blitzortung data to display lighting positions even at high map zoom levels. I saw which building had been struck by lightning. How accurate is lighting locating in reality?
Threads: 66
(2024-07-10, 07:45)rafterhimself Wrote: Some android maps use blitzortung data to display lighting positions even at high map zoom levels. I saw which building had been struck by lightning. How accurate is lighting locating in reality?
(2024-06-21, 04:57)gerbold Wrote: Quote:~~~
Threads: 0
Hello Dear,
Have you some news about the System Blue Mini (functionnal, not testing, PCB 22.2 + PCB 23.1) ?
Many thanks, 73 F4HTB
