Threads: 6
2016-09-12, 11:20
(This post was last modified: 2016-09-12, 11:20 by piepants.)
(2016-09-12, 06:39)Jayson Black Wrote: Hi all. Im not sure if my issue is related to those previously stated, but I have been putting my name down for a system since 2014. i think i have put my email in about 3 times. maybe about 9 or so months aprt in the time since I first registred in 2014. but I have never received an email telling me my nuber has come up, nor even an email regarding a rank. I searched my email archive and could only find two emails regarding a password change. /me shrugs. Is there some other way I can find out my rank? Or do I just add my email again and it will tell me my rank with out re setting my rank? The other thing Im finding curious is that I see at begining of Original Post that "Systems are available" Does this mean the queue is empty?
Anyway, I am extremely keen to get a system blue and add to the coverage.
Im a mega, mega mega lightning enthusiast and lightning chaser. I love this project an dearly want to be a part of it
(Dont we all?)
I put my e-mail down in 2014 too, but it had disappeared when the new "queue" system went live. I put it in again and thankfully was only ranked about 250 at the time (I think around June/July?)... my system is now on the way
Threads: 0
2016-09-13, 07:58
(This post was last modified: 2016-09-13, 08:30 by JiPaul B..)
Please, read the previous messages of this thread before asking something about your registration !...
All the news are in the FIRST message of this thread (last updated August 12, 2016).
Egon changed the system of reservation some months ago. Now you have to reserv (or test your rank of reservation) in the
Cover Your Area Page.
If you
left your email at the Cover Your Area Page you are stored in a reservation list and got a rank. This rank is updated each time Egon send kits. So you have just to wait an email from Egon that will come when your rank will be close of zero. You could also test from times to times your rank just putting
the same email address in the "Cover Your Area" page. But be careful, if you test it when the rank is 0 (or if you make a mistake in your email address), you'll be registered for a new kit !...
(2016-09-12, 06:39)Jayson Black Wrote: The other thing Im finding curious is that I see at begining of Original Post that "Systems are available" Does this mean the queue is empty?
No. It just means "systems are available" and that Egon will send some systems following the queue list order.
Threads: 7
Position #194
Threads: 2
How do I register my station on the site?
Threads: 18
Go to the status page of your controller, make a note of the "Device ID:" under "Controller / CPU". Log into the forums or remain so, go to the site login page top right and enter your existing user name into the "New Username" field and the code found above into the box marked "Register Code". This will create a site user, register your controller and connect your forum username with site username.
Once logged into the site you can update the information about your set up, aerial type(s), which channel has what aerial etc. On the site Input 0 is Ch1A, Input 1 Ch1B etc and dimensions are in mm.
1627
Threads: 2
(2016-10-23, 16:27)allsorts Wrote: Go to the status page of your controller, make a note of the "Device ID:" under "Controller / CPU". Log into the forums or remain so, go to the site login page top right and enter your existing user name into the "New Username" field and the code found above into the box marked "Register Code". This will create a site user, register your controller and connect your forum username with site username.
I do not have the code. what does he look like ?
Threads: 18
Use the web interface of your controller and go to the "Status" page, scroll down to the "Controller / CPU" section and the code is the long alphanumeric string by "Device ID". I don't think you enter the hyphens on the login page.
1627
Threads: 3
(Dont we all?)
I have a little bit different case. I received an email from Egon, but then after some time I requested a details about ordering and payment information, but didn't get any response. Are we limited in time to response and then get kicked from the list?
Threads: 0
Hi Egon ,
Since 1 mouth my rank is still the same 632
is this normal ?
i now wait since montsh last time i checked i was rank 698 now iam 1400 of 1400... makes me sad....
