2014-12-27, 08:25
I will be using ferrite aerials, which needs the 12.3c kit and that is associated with the H field amp (am I understanding this right?) where or why does the F field amp come into things??
When are kits back in stock?
2014-12-27, 08:25
2014-12-27, 09:53
(2014-12-27, 08:25)orion_jb2001 Wrote: I will be using ferrite aerials, which needs the 12.3c kit and that is associated with the H field amp (am I understanding this right?) where or why does the F field amp come into things??The E field preamp connects to the E field Amplifier, which connects to the second RJ45 input on the controller. Make sure your H field is on jack next to GPS, (1), the E field should be on 2, next to USB power.
2014-12-30, 06:13
Ahhh. so do I need to get an H field kit and an E field kit. Again, I will be using the ferrite aerials from blitz??
2014-12-30, 09:49
Man, love to get a kit, are the ferrite antennas good???
2014-12-30, 18:08
(2014-12-30, 06:13)orion_jb2001 Wrote: Ahhh. so do I need to get an H field kit and an E field kit. Again, I will be using the ferrite aerials from blitz?? No, if you are just planning to use ferrites then you just need the H field kit, the E field kit is optional and not suitable for every location as it must be mounted several meters away from any source of electrical interference. (It has its own rod antenna) Ben.
RED Station: 878, Flightradar24: F-EGLF1, Open Glider Network: Aldersht2, PlanePlotter: M7.
Stations: 878
2014-12-30, 18:41
Kit Ordered
2015-01-01, 20:40
From reading the forum, it is obvious that some people have no idea the PITA it is to build one of these systems, especially with SMD components. I spent almost as much on equipment as I did on the kit.
I live in central Mexico and have built all the component parts and have a station running (#1218). I'm retired and if anyone wants someone to build the system and check it out when they start shipping again, I will build up a few for people for $5US a board and test them before reshipping. You will have to drop ship to Mexico (takes 5 weeks from Germany) and pay the shipping to where ever you are. It will take 7-10 days to build a system and run it for a few days to make sure that it is OK. If interested, you can contact me at jrm30655 (at) hotmail (dot) com and I will start a list first come, first served.
2015-01-18, 09:06
maybe now. i received one this days. // hans
2015-01-18, 09:50
