#51
@Tobi
i can give it a try. Where i can find needed Specs about Webservice ?
NosDE (Marco)
#52
(2014-06-11, 19:29)NosDE Wrote: Where i can find needed Specs about Webservice ?
Sorry, but there are currently no specs and no webservice. We are working on it, but it will take some longer time due to high amount of work.
#53
Problem is not solved yet.
Attached parts of report:
Quote:Hardware Model: iPad3,3
OS Version: iPhone OS 7.1.1 (11D201)
Kernel Version: Darwin Kernel Version 14.0.0: Fri Mar 28 21:15:11 PDT 2014; root:xnu-2423.10.70~1/RELEASE_ARM_S5L8945X
Date: 2014-06-11 23:40:57 +0200
Time since snapshot: 61 ms
Free pages: 2150
Active pages: 7357
Inactive pages: 3489
Speculative pages: 534
Throttled pages: 183615
Purgeable pages: 0
Wired pages: 55960
File-backed pages: 11023
Anonymous pages: 357
Compressions: 1062526
Decompressions: 252476
Compressor Size: 135
Uncompressed Pages in Compressor: 122
Largest process: Web
Processes
Name <UUID> rpages recent_max fds [reason] (state)
EscrowSecurityAl <78bed6be170e3270a13630acb6ce976f> 170 170 100 [vm-pageshortage] (daemon)
MobileMail <3f0ef8f605de310e9b97b9a482f41e44> 1280 1280 100 [vm-pageshortage] (resume) (continuous)
tccd <1abc957a1c7d3a5da04ef097be7b6c5f> 157 157 100 [vm-pageshortage] (daemon)
kbd <f6a047c5fa473e5c89c451ac1750c84a> 1202 1202 100 [vm-pageshortage] (daemon)
Web <0eee4f489be83c29955d7f07690691e6> 171477 171477 100 [vm-pageshortage] (frontmost) (resume)
NosDE
#54
As far as running it on a PC is concerned it runs extremely smoothly on firefox 29
I notice though that a link on the blitzortung.org page has been removed.
vooliberista
#55
My Android phone shows the Live Maps display nicely and scales everything correctly. However, I do not see any new strikes at all. The Live Data indicator is flashing yellow very rapidly. The Background Map indicator is green and all of the selectors (Strikes, Detectors & Sound) have a check-mark in them.
I'm running on a Samsung Galaxy S3 using the default web browser on the phone. My connection is via my home wi-fi.
Any ideas what may be wrong? This is the first time I have tried to view the BO live map on my Android phone so don't know if it may be some setting I am missing or not.
Don - W7DRM - Emmett, Idaho - U.S.A. --- Blitzortung Station: 808 --- FlightRadar24 ID: F-KRNO2
Stations: 808
#56
(2014-06-14, 21:29)W3DRM Wrote: My Android phone shows the Live Maps display nicely and scales everything correctly. However, I do not see any new strikes at all. The Live Data indicator is flashing yellow very rapidly. The Background Map indicator is green and all of the selectors (Strikes, Detectors & Sound) have a check-mark in them.
Don, My HTC G3 does fine on Lightningmaps.org realtime... on BO realtime, error "socket not supported by your browser..." no real-time.
#57
Thanks Mike. Same issue on my S3. However, I do not hear the clicks on Lightningmaps.org. The note indicates it may not be available on all devices.
I'm downloading Google Chrome to see if it works any better.
Works fine with Chrome but still no audio. Seems to load and run faster than with the default browser on my S3.
Stations: 808
#58
(2014-06-14, 21:29)W3DRM Wrote: Any ideas what may be wrong? This is the first time I have tried to view the BO live map on my Android phone so don't know if it may be some setting I am missing or not.
Don't know what's going wrong. We've tested with an Android phone and emulators and found no problems so far.
#59
Hi Tobi, as I mentioned above, it is now working fine with the Google Chrome browser but no audio. Audio works fine on other websites so not sure what may be wrong. This is really a great viewer. You've done a superb job putting all of this together.
I can't thank you enough for everything you and the others have done.
Stations: 808
#60
Tobi,
today no crash on iOS - scary, or did you solved something ?
I think it is really time, to go native on i Devices.
-NosDE
