Station 18, with green pcb
For the last 3 days, my green pcb does not show on the server, somehow it disappeared from my account also.
I do have some interference from a solar inverter during the day, but the station was working ok.
Station 18, green pcb 6.8
Thank you.
Stations: 18, 2916
Re register the station and it's on again Confused
Stations: 18, 2916
After receiving an email from you telling me to remove the login password from the tracker program and replace it with a different one, for security reasons my station does not update the server since 2026-07-22 19:55 the time I changed the password and it won't accept the password from my member login.
Stations: 18, 2916
Can someone please tell me if station 18 is uploading to the server? Since the problem with the passwords appeared I cannot see that my station is doing anything.
Thank you.
Stations: 18, 2916
(2026-09-14, 17:37)PetrosKa Wrote: Can someone please tell me if station 18 is uploading to the server? Since the problem with the passwords appeared I cannot see that my station is doing anything.
Thank you.
As of around 2026 September 19 01:40 UTC on the project area--station list
2916 was shown currently as idle but it appears there is impluse noise from something very often.
18 Running but absolutely no data
both appear to be in a strange state.
Someone else will have to help you debug.
Stations: 1660
18 is one of the legacy GREEN systems.
I wonder if there may have been some confusion over the password change after the forum/security problem.
The GREEN Tracker itself uses a username/password to authenticate with the Blitzortung receiving system, and historically that password was not necessarily the same as the forum or member-login password.
You mentioned that Station 18 stopped updating at exactly the time you changed the password in the Tracker on July 22. That makes me suspicious that the Tracker may now be using a password the receiving server does not recognize.
I would not assume your current forum/member-login password belongs in the GREEN Tracker. If you still know the GREEN Tracker password that was working before July 22, that may help identify what happened —
The fact that Station 18 is shown as Running but with no data would also seem consistent with the GREEN hardware/station registration existing, while the Tracker is no longer successfully delivering authenticated data.
Someone familiar with the current GREEN authentication setup probably needs to confirm which credential Station 18 should now be using.
Ok so I deleted the station 18, but how do I register the station again? I forget how to do it, it asks for "Assign a new station:
(Processor-ID)"
Thank you.
Stations: 18, 2916
