(2020-08-12, 18:03)Slavkowski Wrote: User name: slavkowski (2086)
Station: 2774
Region: Europe
1. I'm not able to assign station to user. I've been trying to assign my new station to my account since yesterday but somehow it didn't work.
2. How I Can change my status to: Participant?
Status updated
Station: 2774
Region: Europe
Status updated
Thanks.
Is there a chance you give me a hint about my first problem?
I tried to tied my station(Processor-ID) to my account but still it didn't work.
Station: 2774
Region: Europe
Status updated
Thanks.
Did you plug your controller Device-ID number, (Connect to your controller and scroll to Controller/CPU)
into the Processor-ID field of your BO profile? Just the numbers, no dashes (-).
Station: 2774
Region: Europe
Status updated
Thanks.
Yes, I tried several times put Device-ID from Controller/CPU to "Assign a new Station (Processor-ID) in my profile. Every time I got notification that Processor-ID has been added. But i don't see any changes. Still my station is no assigned.
@Slavkowski / dupreezd: May I suggest that you continue in another thread about the connection problem?
Due to a previous discussion already my request seems to be lost, so I'll repeat:
User Name: lt.ning
Station Number: 1974
Region: currently Asia, Oceania
Station: 2774
Region: Europe
Status updated
Thanks.
Update: I solved this issue by assigning my station to newly created user using link on BO controller page. (I'm aware that it was against the advise from BO, but this solution worked fine and my station is finally assigned).
User 1968 (Rejean)
Station 2521
Region: North America, Canada, Ontario, Whitby
Station no longer appears as active / participating
Note: There may be 2 database entries. The original active one showed 2 ferrites, and latter one E-Field only.
H-Field preamp fried and only using E-Field now for moment.
Station: 2521
Station 1684
Why is the Asian listing displayed? How can you remove Asian? Leave only European?
Stations: 1684, 2917
(2020-08-18, 14:53)malyan Wrote: Station 1684
(2020-08-19, 15:09)cutty Wrote: This question keeps repeating...already answered at least once in this thread alone:
Quote:You are listed twice because your station is server configured to report data covering 2 regions.  Lightning maps will show stations depeding on which region you've logged into on LMO. If no signals are shown in a region, depending on variousd parameters and time frames, you may not show on a specific region listing.
 In this case supporting both Asian region, and Europe.  If you select "all regions" on Blitzortung Station list, you will see 'both' regions.
If removed from Europe, you will no longer help locate for that region. Normally, only selected stations due to quality and location directly support multiple regions.
(2020-08-16, 23:34)Rejean Wrote: User 1968 (Rejean)
Station 2521
Should I go to the https://www.blitzortung.org/en/user_data.php site and delete my data and re-register my unit ?
I'm in middle of major lightning here, but the graph there shows nothing since end of July.
Even though my H-Fields are out, I have E-Field working which is suppose to be sending.
On the https://www.lightningmaps.org/blitzortun.../index.php page, i see two entries for my station 2521.
The one which has my E-Field  24inch shows some graph, but it is not coming from my station.
Any suggestions to get me back on again ?
UPDATE Aug31-2020 :  Got stuff working again !!!
I replaced the 3x  THS4531 chips on the H-Preamp, (these got fried somehow and only had E-field working),
and I started getting H-filed signals again at the controller.
I emporarily disabled the "Need Authentication" and enabled the "Guest" on the controller's web interface.
I then logged into the blitzotung.org site, and again added my device ID.
Yeppie !!!  the web page portion to enter antenna info etc now appeared.
I entered the info, changed Anonym from Y to N, saved it, and then presto ... my controller now shows my user ID which it didn't earlier.
Things now appear to be somewhat back to normal.
User 1968 (Rejean)
Station 2521
Station: 2521
