Threads: 5
I can download 9.1...it appears as a .bin file
But I do not have any Tools page....in my controller page..
I have login, Status and About.....those are the only tabs at the top of the page
Station 0
FW 9.0b1PCB 19.4/H1/E1
SYSGPSNETAMPSIG0/s00:00:46
Login
Status
About
Auto Refresh
(Manual entry by admin: Station 2334)
2334,
2382
Threads: 5
(2018-12-04, 02:49)Mike Wrote: I can download 9.1...it appears as a .bin file
Station 0
Login
Status
About
Auto Refresh
Can you post a screen shot?
Threads: 5
(2018-12-04, 02:52)dupreezd Wrote: (2018-12-04, 02:49)Mike Wrote: I can download 9.1...it appears as a .bin file
Station 0
Login
Status
About
Auto Refresh
This is what mine looks like
Threads: 8
2018-12-04, 06:13
(This post was last modified: 2018-12-04, 06:16 by vk2him.)
Mike-
The problem is that you have enabled "Need Authentication" under Web Interface in the settings tab and you are viewing the Status page as a guest - in other words you have not logged in to your controller yet so most stuff is hidden including the Device ID numbers you need.
To make this work, you need to press the Login link and then login using the username and password you created initially. Once you're logged in you will be able to view the Device ID numbers you need. Unless you specifically want to user that login facility, you can disable the "Need Authentication" . Most of us don't have it enabled as we don't have our controller's status page exposed to the internet using port forwarding.
Hope that helps. Cheers
Threads: 5
Ok, now we're getting somewhere....Vk2him, you were correct...I know have the full list as described....
Seems, putting in the INCORRECT PASSWORD does not flag it as incorrect and I was assuming that I was actually logging in with the CORRECT PASSWORD....
Woke up at 1:45 in the morning still thinking about this and happened to get up and check this form and you guys came through....Thank You, Thank You.....but I'm going back to bed.....
2334,
2382
Threads: 5
Good Morning,
I've updated the firmware to 9.1..... everything seems so simple with a little help from "Friends of the Forum"
Thanks Very Much... I'm sure I'll have more questions down the road...
Eagle River
2334,
2382
Threads: 5
2018-12-04, 15:11
(This post was last modified: 2018-12-04, 17:12 by cutty.)
Finding my user #XXXX and station #2334 after logging into the Contributors site..... I see myself on the Users List but not on the Stations List...
and how do I know if I'm a fully reporting station....
Thanks Again,
Eagle River
(mod:removed user#-public thread-)
2334,
2382
Threads: 66
2018-12-04, 17:22
(This post was last modified: 2018-12-04, 17:22 by cutty.)
(2018-12-04, 15:11)Mike Wrote: Finding my user #XXXX and station #2334 after logging into the Contributors site..... I see myself on the Users List but not on the Stations List...
Thanks Again,
Eagle River
Not sure this is complete issue... but if you have 'anonymous' "
Y" on your station config page, Make sure it is "
N".
You may also be a 'victim' of the new server databases and processing still a bit groggy ... additionally it may take a couple of hours
to update presently... I'm not sure what schedule he has it running on.,.. or which regional servers he's working on.
Threads: 66
(2018-12-04, 17:22)Cutty Wrote: (2018-12-04, 15:11)Mike Wrote: Finding my user #XXXX and station #2334 after logging into the Contributors site..... I see myself on the Users List but not on the Stations List...
Thanks Again,
Eagle River
Not sure this is complete issue... but if you have 'anonymous' "Y" on your station config page, Make sure it is "N".
Check your Email ...
Threads: 5
Cutty,
Anonym has always been set at "N"....
2334,
2382
