Hi all.
Just got my System Blue built and ready for use, however, I currently don't have a housing for the unit.
I have a laser cutter and access to a 3D printer.
Are there any laser cut files (I will make out of acrylic) or 3D print files available for System Blue so I can make my own housing?
If so, could you please point me in the right direction.
Thanks in advance!
At first, I just hung my controller from whatever was handy along the wall of my basement. Later, I copied what Cutty (Mike, one of the moderators here) did and used a clear polycarbonate anti-static hard drive shipping box. Photo at http://www.w0btu.com/files/misc/Lightnin...1977photos.
But it sounds like you can do much better that I did!
EDIT: Where are you located?
Thanks Mike.
I'm located in Melbourne, Australia. There's a couple of sites around the city already, but the strike detection rate is usually quite unreliable. I'm hoping this system will greatly improve that.
It's being installed on the roof of a medical facility, and the controller in a server room, so it all needs to look very professional.
Ah, I was wondering where the controller would be located, inside, outside, hidden or on view. In a server room a 1U rack case containing the controller, PSU, with connectors on the back and blinking lights on the front might be easy to install if there is rack space... Something like:
http://cpc.farnell.com/unbranded/rcg-21-...dp/DP29116
http://cpc.farnell.com/penn-elcom/r2110-...dp/EN55275
Not so much fun as making something from scratch though.
Is it too late to buy the housing from Ergon? It's a great looking enclosure, albeit relatively expensive ...
Stations: 2039
I've designed and test cut a box on the laser. Just needs a few adjustments and I'll have the final design. I'll post the files here for anyone looking to make their own
Stations: 2120
I've made a couple of prototypes now and have my final design.  I may still do some tweaks, but I'm fairly happy with the result.
The first prototypes were made using plywood, and the final in perspex (acrylic).
I kind of like the plywood.  Gives a steampunk look to things (perhaps I could add nixie tubes to the top!), but the perspex is much more professional.
If there's enough interest, I can probably make a few more.
[Image: IMG_4308.jpg?raw=1] [Image: IMG_4313.jpg?raw=1] [Image: IMG_4312.jpg?raw=1] [Image: IMG_4320.jpg?raw=1] [Image: IMG_4314.jpg?raw=1] [Image: IMG_4315.jpg?raw=1]
[Image: IMG_4316.jpg?raw=1] [Image: IMG_4317.jpg?raw=1] [Image: IMG_4318.jpg?raw=1]
Stations: 2120
I love the wood one though security wise .. if ever a component get's hot or a little spark .. can be dangerous ...
really very nice work
both looks good... actually, i recall the raspberry pi do have wooden casings available as well.
Perhaps those at Australia can get their casings from you if interested/download it when you share.
Stations: 1876, 2013, 2257, 2272
Looks great! I'd love the wooden one however I already bought the metal one ..
Stations: 2039
