2017-10-28, 15:58
Station: 2 stokes with 2 signals sent:
Efficiency = 2/2=100%
Effectivity = 2 / (2-2) 0=???%
Efficiency
2017-10-28, 15:58
Efficiency = 2/2=100% Effectivity = 2 / (2-2) 0=???%
2017-10-28, 16:06
Hi All, Help, advice and education must be the Key here. I certainly don't want to see stations arbitrarily ignored if their station is not up to scratch.
Getting in touch with these people and letting them know that there is a problem with their station and that advice is available to help them resolve it if they can't work it out for themselves. This is a hobby and most people will take good care to make sure that their station is doing the best that it can. We all know, that sometimes real-life means that hobbies do not always get the attention we would like to give them! Maybe better advertising of the Buddy system and people pairing up to keep the enthusiasm going would help? Unfortunately not many of these stations post in the forums asking for this help, therefore they will have to be sought by other means initially. Regards, Brian.
2017-10-28, 16:12
Efficiency = 2/2=100% Effectivity = 2 / (2-2) 0=???% This is why we need a better Algorithm? Make some useful suggestions!
2017-10-28, 16:23
Well. My overall belief is 'one stroke' located accurately with 1001 signals is better than zero strokes "detected" per 1000 signals sent... in order to have detected that 'one stroke' the station sent 1001 signals... but became the final 'locator' required to register a stroke...while the other 'locators' only sent 500 signals ---while its 'efficiency' / 'effectivity was nil, especially if compared to the other locators, the benefit to the network was 'effective'... it enable the network to achieve the network goal, with a whole lot of effort on the stations part, and that critical station show's lousy efficiency / effectivity 'uniquely' . Conversely, network 'effectivity' / 'efficiency' is not necessarily related to a stations capability or performance as a unique station.
Also consider that some percentage of virtually any stations' signals ARE skywave reflected strokes, but timing and distortion of signals, and lack of reception by enough other stations, does not result in it being 'recognized' and is scores as a signal, but not a stroke... thus lowering any efficiency / effectivity. If I choose to operate at a short range only, I can be highly effective, and efficient, as far as my "Goal".. see my above post... my goal being most efficient and effective at <500km for example. But related to 'network' I will almost always not contribute as many strikes... especially if compared to 'network' totals. If considered 'uniquely', in other words, 'how am I doing for my environment, established goal, etc'... my 'long term', seasonally, situationally, geographically, has a better chance of contributing better 'quality' data to the network, rather than a high 'quantity'. I send a LOT more useless signals than I'd prefer.... it's an environment issue. I can back those down by decreasing range, except when a couple of near disturbers flare up that are very strong, and the burst repetition timing does not trigger 'burst mode' interference... I'd prefer to go interference, not send signals, as the design intent... these disturbers don't make critera for interference modes . Therefore my network contributions on either system are nothing like their potential. But, having establishing both 'normal' and 'situational' operating goals, I consider my two stations quire effective and efficient, all things considered. Its NOT the equipment... its the situation and my established paradigms. For me to compare my stations with stations in a super quiet environment, such as Brian and Mike encounter, is absurd. I can 'never' match them, except in rare situations. Now Three years ago, before the environment degraded, I'd go 'head to head' with anyone... And I believe that stations that attempt to 'match' other stations 'performance', be 'on top' of the 'effectivity' tables may well be chasing a dream, which is fine... after some time, I think a lot of us come to realize that this is a "Team" effort, and we put our stations in a position of performing as well as possible, with maximum 'unique' efficiency... BRIAN, the 'communication' between server and controller is NOT a 'triggered signal'. PASENSE, I totally agree with you.
2017-10-28, 16:26
2017-10-28, 17:01
Dear Cutty, Of course you are correct, there is a happy medium.
My station Square lights up with only two or three others and sometimes there are not enough stations to register a stroke, maybe it is not the right sort of lightning. Who Knows? Certainly for very near storms or heavy interference it is best for any station to stop sending to the server, that is the benefit of the network, most of those strokes are still going to be recorded by other stations, a thousand to one ratio seems reasonable under certain conditions, 100,000:1 is maybe less acceptable? Comparing apples and oranges is not easy and most of us are trying to do our best. I think what Egon is trying to find is a reasonable middle way and if that means excluding stations outside of certain limitations, so be it. What you and the older stations have learnt has lead to the better development of the stations, over the years, greens to reds to blues to xyzs. There will always be improvements and compromises possible, but we can't just sit on our laurels (or whatever!) and say that's it we are finished. There is some way to go yet? Brian.
2017-10-28, 19:07
(2017-10-28, 08:24)Breitling Wrote:(2017-10-27, 09:15)readbueno Wrote: Hi All, We need to define what we each mean by "efficiency" and agree on a common definition? Your graph with the diagonal lines is GREAT !! I am always holding a straightedge up to my monitor. In some cases I have saved screenshots and added the diagonal lines with GIMP (a free OSS Photoshop clone). They should be added to that webpage.
2017-10-28, 19:16
(2017-10-28, 16:06)readbueno Wrote: Hi All, Help, advice and education must be the Key here. I certainly don't want to see stations arbitrarily ignored if their station is not up to scratch. Indeed! Some stations need to be contacted and help offered to them.
Cutty, You should not be so modest.
Your instructions have been of great assistance to me whilst setting up my station. Yes, I have taken the time to read most of the forums and I do monitor other stations for comparison with what I am seeing on the screen of my own station. I am still improving, slowly. Both your Red and your Blue stations seem to be always fairly near what most would consider about the optimum on the graphs! I.e. You have taken the time and made the effort to find your station's Sweet spot. The out-lyers on the graph, appear to be the problem and there are not many that could be accused of too little gain or too high a threshold, most of the stations that we are referring to, would err on the side of "high gains, low thresholds" or have a serious source of interference local to their station. Auto, or semi-auto does not work at present, if your station is not reasonably well set up to start with? This accounts, overall, to quite a small percentage of stations, but some of these stations send more signals per hour, than the rest of the Network combined. I am not "trying to teach my Grand-Mother how to suck eggs!" but Egon did ask our for our opinions and suggestions, and it seems only polite, to respond with our views of how things are from a personal perspective. I am sure if I was in the "centre" of the network, I might be trying to defend a different view! Discussion in the forums is very stimulating, but how many operators actually read the forums and take note of the suggestions made there in. Some of the less well managed stations appear to be in "Institutions," where perhaps, they are not the responsibility of an individual. "What is the work for all, becomes the work of no one?" You only have to look at the stats to see glaring examples of this! May be this is a different issue, but it appears to be at least part of the same problem, and needs to be addressed? Brian.
ok, I will try to sum up some things i heard:
There are different criteria for optimization for different locations. So if we want a station to be optimized for certain criteria, then we need a separate value for that. This location specific value should be high when the station is optimized for it's position in the network. That means for stations at the border of the network:
For the local optimization the criteria are different. We all cannot change the position of our detector, but what we want to achive is a good signal to noise ratio. So we need some help to find the right amplification, threshold, filter frequency or quality of the power supply. For that we should get help e.g. like this:
Supporting the first station in India 1974
Stations: |
« Next Oldest | Next Newest »
