Should we have a FAQ?
Hi All, Despite having a measured, with a DVM, a voltage of 5.02 Volts at the usb mini "B", the voltage that is showing when I look at Vin on the signals page is giving me 3.96 Volts.
I have tried several different power supplies and these two figure only vary by a very small amount.
What is the problem?
What should I be looking at to fix it?
Thanks,
Brian. Huh
Measure the voltage on the 3.3v regulator for the CPU.
IC502 between the CPU and the buzzer.
Should be asking in the internal forum under troubleshooting.
(2017-09-22, 10:30)kevinmcc Wrote: Should be asking in the internal forum under troubleshooting.
Brian, Kevin is right! Posting your problem there would be best for you.
I should have posted what I did so far in this thread to a new thread of its own. And I plan on doing that from now on. Anyone who wants to start a FAQ page can look at mine and many others' threads.
(2017-09-18, 10:03)readbueno Wrote: Hi Pasense, Unfortunately, also many of the threads just fizzle out without any conclusion. ... However there are still many blanks, I have several pages of questions that reoccur many times, many of which are possibly still relevant.
The Blue Documentation has not kept up with the board versions.
Agreed. Lots of folks have 'complained' about that.
With all due respect to them, the developers are likely not going to update the Blue docs as we would like them to. Nor should we expect them to! They have stated that they have families, this is a hobby for them, and they don't have time. What is more, the devs are concentrating on the important tasks of improving the hardware and software. And we should be grateful to them for that.
A FAQ or other detailed help docs should be done by others. (That's us, people! :-)
I have personally experienced that when I either invented or help develop a product --and then wrote a manual for it-- it was utterly confusing for the end-users. Why? Those in that position assume too much. We leave out important details. Any manual, etc. should be written with help from those struggling to use what we created.
I will help as I have time. But I call on others who struggled with figuring out how to get their System Blue working (like me) to roll up their sleeves and help. :-)
An FAQ would be wondeful, the forum search is, erm, "not very good" or at least I can spend ages trying to make it spit out a topic and or post that I *know* is in there somewhere.
I've had half an idea to pull just my posts together into some form of mini "FAQ", that's why some of my posts go into more detail than is probably required. I can also find all those, relatively painlessly, via my profile.
I quite like Wiki's but they can get out of control, they really need someone to set a style, create suitable templates and tidy up entries to match the style.
Hi All, This FAQ would not be a random forum.
1. To start it would have limited write access and a separate public discussion forum for debate and new questions.
2. There are many questions that are asked in the forums that are not answered that most beginners have asked and these should have an organised central page.
3. Forum Searches and Wikis imply that you at least know what question to ask. For many newbies, and others, this may not be the case.
4 We are quite a small Network at the present and the forums are growing. They do contain a lot of information, but also a lot of "Cul de Sacs."
  With growing numbers this will only get worse.
5. It Would be Limited to the most common and basic questions with short answers and links to more detail where required. +Don't forget the discussion forum.
6. If we set this up now, it will be easier to set up and maintain than when we have a 100,000 posts and 10,000 topic all over the forum.
7. It should not just be one person, from experience I know. It should be a fairly small group, so that if one person drops out it will continue to function, with an occasional call out for new volunteers so that there can be some rotation of people and ideas.
Mike is right, this is not a job for people that are already doing so much for the network! "We the people" should be able to get this organised!
Just my 2 cents,
Brian.
I started this thread some time ago and I have collected some encouraging and some less encouraging comments from you. This is now my conclusion of what was communicated and my updated proposal (so don't blame anybody else if you don't like it).
  • The FAQ should only be on system blue, because that's where most questions of a general nature will come up.
  • Only relative simple things should be included in the list (see below), specialized technical question will still need to go to the normal forum.
  • The list should be short, otherwise people won't read it anyway. I think it should completely fit onto the screen, say less than 25 lines.
  • The whole effort should be limited and we should gather feedback from readers before considering going on.
This list is an example of what could be in such a FAQ:
  1. What do I have to know to be able to assemble and run such a system?
  2. How do I get one of these system blue?
  3. How do I check where I am on the waiting list?
  4. I received the kit, how do I solder the stuff together?
  5. What power supply should I have?
  6. How do I access the system interface?
  7. How do I test the assembled system?
  8. How can I register my new station?
  9. What antennas should I have?
  10. Where should I place the antennas?
  11. How do I check for noise and why should I?
  12. How do I hunt for noise sources?
  13. Should I use the optional low-pass filters?
  14. How do I solder the low-pass filters?
  15. What are the most important settings in the system interface?
  16. What are these funny wiggles before/ after my signals?
  17. ….
Stations: 1836
(2017-09-26, 16:21)pasense Wrote: I started this thread some time ago and I have collected some encouraging and some less encouraging comments ...
This is a GREAT start! Thank you for this. :-)
I can't think of anything right now to add. However, as for the text being all on one screen, I assume you mean each point rather than the entire FAQ
On the other hand, the FAQ text could be limited, with links pointing to more detailed threads, both existing and yet-to-be created. Some answers are going to be difficult to put a tight limit the text length.
  • One thing that could (should?) be done is make the points stand out by good text formatting.
  1. A brief summary at the top, a "tl;dr" if you will.
  2. Each main point, subject, etc. in larger and/or bold text. Paragraphs below that in smaller, plain text could be indented for easier reading.
I have a list of useful links to various threads here that I've been meaning to post here. Anyway this is my $0.02 worth for now. Thanks again!
I would like to add maybe a section detailing the settings on the controller area of the board. A few of those settings are unknown on how they technically work and there are little to few answers to people’s questions on the forum about them.
Stations: 1955
No Blame! This Is a GOOD IDEA!
Hi All, Blue it is, because that is what we have now, there is already a lot on Red that is historically fun to read, but it won't necessarily help you start with Blue.
Here's one that should fit in there some where.
XX.What happens to all the data?
Another
XX. What are the initial settings and adjustments? What more can I do?
And another:-
XX. What do the LEDS do and show? (Most are self explanatory, but Mode, Fault and Alarm need more.)
Explain Effectivity?
I also agree with Mike, we need forums and discussion links, "both existing and yet-to-be created. Some answers are going to be difficult to put a tight limit the text length."
The interference thread:-
http://www.wxforum.net/index.php?topic=20439.0
Is a good example
Layout will be important, First to catch people's attention and to make it easy for people to read.
More suggestions to what we already have:-
What do I have to know to be able to assemble and run such a system? (Space available, extra costs, Internet connection type? etc.)
(What else do I need?) (Cables, Plugs, containers, mounting equipment, Test Equipment etc. For example!)
What power supply should I have? (Very important, and vastly under estimated in the current Documentation. Your average Phone Charger and USB to USB mini B adapter just wont cut it!)
How do I test the assembled system? (Is it in fact working as it should, but just not up to my expectations, due to other factors. Test points, DVM tests, PC based Oscilloscopes, A full test Lab?  Wink )
"What can I do if it doesn't work?"
What antennas should I have? (The Present ferrites and a short rod antenna are pretty good if there is sufficient network support around you, anything more and there is a great deal already written that is applicable regardless of the system.)
Where should I place the antennas? (I Think more Where should I not place my antennas! Big Grin )
How do I check for noise and why should I? (Time constraints, What is noise?)
How do I hunt for noise sources? (Identify them, The obvious ones in your own house, in the average urban or rural setting! Natural noise, "Huge Noise" that will not be changed, etc., etc.)
We Need to get them in the "right/logical" order?
I wish to help.
Brian. Smile
