Often the connection to the Internet (router) is lost how to fix it?
Stations: 1684, 2917
Is the Blitzortung detector the only device having the issue?
Can you ping or access web page of the Blitzortung detector without any issues?
Вы используете kабель F/FTP или kабель или S/FTP kабель SF/FTP с H предусилитель?
https://ru.wikipedia.org/wiki/Витая_пара
(2017-03-22, 04:00)kevinmcc Wrote: Is the Blitzortung detector the only device having the issue?
I think malyan's controller isn't very happy. Over in the order status thread it's mentioned that the red H-field LED goes off. I think that refers to the LED on the H-field preamp board. That LED is connected across the 5 V supply of the pre-amp board. That 5 V pre-amp supply is fed directly from the regulated 5 V rail on the controller board.
The H-field pre-amp LED going off indicates a problem with the 5 V on that board. This could be a connection problem, poorly crimped plugs to screened cable, dry joint on the socket connections to either board. Or it's a problem with the 5 V rail of the controller, which I'd expect to be related to the power supply being used.
We need more information from malyan:
With everything connected up which lights are on, off, regulary flashing or randomly flashing 5 minutes after the unit has been powered up?
Can malyan get to the controllers web interface?
If so what does the Status > Controller / CPU section say?
I don't read or speak Russian so haven't any idea if this google translate is any good.
Я думаю, контроллер Малиана не очень доволен. В потоке статуса заказа указано, что красный светодиод H-поля гаснет. Я думаю, что это относится к светодиоду на плате предварительного усилителя H-поля. Этот светодиод подключен к источнику питания 5 В на плате предварительного усилителя. Это предварительное напряжение питания 5 В подается напрямую от регулируемой шины 5 В на плате контроллера.
Срабатывание светодиода предварительного усилителя H-поля указывает на проблему с 5 V на этой плате. Это может быть проблема подключения, плохо обжатые клеммы для экранированного кабеля, сухой разъем на разъемах на любой плате. Или это проблема с 5-вольтовой шиной контроллера, которую я ожидал бы связать с используемым источником питания.
Нам нужна дополнительная информация от malyan:
Что все подключено, какие лампы включены, выключены, регулярно мигают или случайно мигают через 5 минут после включения питания?
Может ли malyan попасть на веб-интерфейс контроллеров?
Если да, то о чем говорит раздел Status> Controller / CPU?
Я не читаю и не говорю по-русски, поэтому не имею ни малейшего представления, является ли этот перевод Google хорошим.
I took two semesters of Russian in college 17 years ago, I very rusty.
You probably are right about power issue.
I told him to make sure he had proper shielded cable for H-field.
FirmwareRev. 8.2 BLUE / Sep 29 2016 14:10:51
HardwareRev. 19.3 (PCB-Id 50)
Device-ID2600-2A00-0B51-3533-
HCLK / SYSCLK / PCLKs168 / 168 / 42 / 84 MHz
CPU28%, 34.7°C, 3.25V
Max. Memory usage114kB + 65kB for Signals
Signal Buffers15
Input Voltage4.73V
Availability100.00%
TypeMediatek with 115200baud (FW: AXN_3.20_3333_13022801,8030)
StatusActive, 3D-fix
Satellites8 tracked, 13 in view
Date/Time2017-03-23 10:41:47
Position56.844181° 35.838924° 120.4m
Smoothed56.844215° 35.839164° 130.4m (smoothed over 20m, 55s)
PDOP/HDOP/VDOP1.38 / 1.09 / 0.85
Sat. Signals (SNR)
28 20dB
30 23dB
13 18dB
8 17dB
15 40dB
20 34dB
7 24dB
5 23dB
11
27 17dB
18
17
21
PPS AccuracyMean: 11.8ns, Current: 0ns
Network cable Electraline FTP cat 5e 4х2х0.52 mm
Red H-Field LED is OK
The station registers signals at a distance of 2,500 kilometers, but communication with the Internet often disappears.
