Threads: 1
I recently set up a System Blue.
The Fault LED is turned on. What does that indicate?
The controller indicates a GPS signal and Network (GPS led blinks, Network LED is turned on)
I wasn't able to find a description about how the LEDs should be interpreted. Is there such a description?
Threads: 75
Can you reach the web GUI?
Threads: 26
The fault LED lights when the controller is in interference mode. Whether it lights under other conditions I do not know.
Threads: 1
(2016-06-30, 10:19)Andrew.Instone-Cowie Wrote: The fault LED lights when the controller is in interference mode. Whether it lights under other conditions I do not know.
Thanks.
I rearranged some cables and positioning of the antennas. The station is up running now.
Threads: 6
i have the same problem but it´s the alarm red is on all the time ??
Threads: 8
2016-09-14, 11:00
(This post was last modified: 2016-09-14, 13:18 by elythomaslumber.)
(2016-09-13, 09:29)LennartJ Wrote: i have the same problem but it´s the alarm red is on all the time ??
What abput the other LED's?
What about the Web-GUI, can you read the system status on the browser?
Are you in "normal" mode or "interference"-mode?
73 de Hartmut / DK5LH
1582
Threads: 1
(2016-09-14, 11:00)elythomaslumber Wrote: (2016-09-13, 09:29)LennartJ Wrote: i have the same problem but it´s the alarm red is on all the time ??
the other LED's? they ar ok
What about the Web-GUI, can you read the system status on the browser, how do i do that?
no interference.
Threads: 8
(2016-09-15, 09:41)Bergkvar Wrote: (2016-09-14, 11:00)elythomaslumber Wrote: (2016-09-13, 09:29)LennartJ Wrote: i have the same problem but it´s the alarm red is on all the time ??
no interference.
Aehmmm, you never did any configuration on the embedded web-server of the system?
Maybe there is a misunderstanding...
- Check your router and find out what IP adress your System Blue got
- type in the IP adress in your browser
- you should see now the WEB-GUI and all information or configuration tabs
- see also here:
http://de.blitzortung.org/cover_your_area.php?session=1 ; download the manual and read beginning of page 69
- maybe you did not disable AMP1 or AMP2 if there is no antenna connected to any of the input terminals?
Good luck!
1582
Threads: 6
(2016-09-15, 16:33)elythomaslumber Wrote: (2016-09-15, 09:41)Bergkvar Wrote: (2016-09-14, 11:00)elythomaslumber Wrote: (2016-09-13, 09:29)LennartJ Wrote: i have the same problem but it´s the alarm red is on all the time ??
no interference.
- see also here: http://de.blitzortung.org/cover_your_area.php?session=1 ; download the manual and read beginning of page 69
Good luck!
Thank i find it now its working fine now
Threads: 3
(2016-09-16, 12:01)LennartJ Wrote: (2016-09-15, 16:33)elythomaslumber Wrote: (2016-09-15, 09:41)Bergkvar Wrote: (2016-09-14, 11:00)elythomaslumber Wrote: (2016-09-13, 09:29)LennartJ Wrote: i have the same problem but it´s the alarm red is on all the time ??
no interference.
Good luck!
I also have an error.
And no interface available.
Hardfault error
Please report
LR=8038f73
PC=80347d4
Firmware 8
After reset unit works.
