I need Help
Hi
my detector is pcb6 version 3.
where i can find the drivers to connect to windws 7. i can not select a COM because it isnt reconoice by usb.
Someone can help
thankx
Stations: 1394
I think PCB 6v3 has a serial connection  Huh
So you'll to connect it to a RS232 (COM) port on your PC.
On new computer there might be no COM port left so you need a Serial to USB converter (I use this one: http://www.digitus.info/en/products/acce...-da-70156/)
thaks i will find tomorow one.
Stations: 1394
i got a cable it is use serial on the detector and usb on trhe computer
Stations: 1394
Is your problem solved?
near...
on the bord the light in red on, green on and the blue is flashing.
The orange dont show....
i download the software serial tracker 6 and it is say
RS232:
COM2 open 115200 8, 1 N
PASSWORD:
verified
RECIVER:
No data
please check your settings
STATUS:
NONE
There isnt any manual?
Stations: 1394
log file:
Program closed
0000-00:00:00 Windows 7
0000-00:00:00 C:\..........\X86\serial_tracker.exe
No new version available
0000 00 00 No input
Program closed
0000-00:00:00 C:\.........\X86\serial_tracker.exe
0000 00 00 No input
Program closed
Stations: 1394
; Please don't change any value
; unless you know exactly what you are doing
; Delete this file to get the standards
[Global]
ApplicationName = WindowsTracker
Version = WindowsTracker_6.20.2 © E. Korffmann 2015
[Start]
Delay = 0
[Setting]
Username = meteolasolana
Password = **********
Verified = 2
Min = 0
Autostart = 1
Logfile = 1
GlobalSharedMemory = 1
Beep = 0
Timer adj. = 0
FirmwareVersion = -
; Critical Section, setting the wrong values will may stop your system
Peak = 1.000000
[Serial]
Port = COM6
Baud = 500000
GPS Baud = 4800
Data = 8
Stop = 1
Parity = N
Handshake = 0
[GPS]
GPS = 1
WAAS EGNOS = 0
[Monitor]
X Value = 800
Y Value = 405
[Graph]
Type = 1
[String]
Space 1 = $
Space 2 = .
Space 3 = $
Space 4 = $
[Screen]
X = 1425
Y = 53
[Server]
Region = 0
Stations: 1394
