An interesting project/use....
Lots of potential noise with an aircraft, but far less than an old Ford idling down the block aways.
I had problems with an ADF (close to the same frequency range) and it was easily solved once a bad bypass capacitor in the charging system was found.
Most aircraft frequencies are VHF and above. Little use for NDB navigation now.
I'm not sure where the concern for interference came from, seems less likely from the aircraft than from the environment that it is flying over.
Stations: 976, 1505
