Threads: 45
What can you not log into? Your controller interface or a web site?
Threads: 7
2019-09-15, 14:47
(This post was last modified: 2019-09-15, 14:55 by opadavis2.)
(2019-09-15, 04:46)mwaters Wrote: What can you not log into? Your controller interface or a web site?
If I were to sign out of "opadavis2", I would not be able to sign in under my original user name "opadavis". When I ask for a new temporary pass code, I am told that code is not valid.
As for not being able to monitor and change settings on the interface, I will again go through the initial steps as stated in the Assembly Instructions for Blue.
This could be related: I just looked at Lightning Maps.org and it shows my station sending signals all night and being active. My station was
off all night.
Peter
Threads: 45
Maybe the problem is that you have two user names. Although I have two stations, I have only ever had one user name and password.
As for your idle station showing strokes, that is a known bug. Those strokes are from someone else's station.
Threads: 7
(2019-09-15, 19:24)mwaters Wrote: Maybe the problem is that you have two user names. Although I have two stations, I have only ever had one user name and password.
Thanks Mike,
I have had only one user name for the past 2 years, until last night, when I had to create another one in order to get access to the forum to ask for help.
Peter
Threads: 64
(2019-09-15, 20:27)opadavis2 Wrote: (2019-09-15, 19:24)mwaters Wrote: Maybe the problem is that you have two user names. Although I have two stations, I have only ever had one user name and password.
Thanks Mike,
Peter
Pete, I also could not reset your password for
opadavis, for some reason.
I merged the
opadavis user to
opadavis2, so please continue with the new id,
opadavis2.
...all your posts, etc should now be in new forum user opadavis2
Strange...
