System BLUE 22.2/H2 - No Signals
Hi everyone,
since a few weeks my System BLUE (22.2/H2, Firmware 11.0b3) no longer receives any signal. In the web-frontend I see that the AMP and SIG status are always red.
The gain setting is set to auto and changing every few seconds. When I enable the noise floor it is extremely low and not changing when the gain is changing.
My first idea was a defect in the H-Field AMP (23.1), as it's still without housing - though the status LED is always green, like before. After replacing it I still see no change, so it seems to be the main device. I also changed the network cable as well as the USB power supply. No change.
Recently I noticed that the device sporadically gets quite warm. If I look at the PCB itself I see no signs of magic smoke.
Any hints what I could do to further debug the device?
Jochen
first hint : what is your station number ... allows othres to have a look at the graphs etc. Cool
(41 minutes ago)Eric.Wouters Wrote: first hint : what is your station number ... allows othres to have a look at the graphs etc.  Cool
Sorry... I missed that one. My station number is 3210.
Here is a screenshot of the signals section.
[Image: screenshot_2026-08-01_blitzortung.png]
Here are some log entries of the debug log (AMP logging enabled):
Code:
2026-08-01 19:37:47 286.7 | AMP1-1: rgain=0 rgain_max=6400 2026-08-01 19:37:47 286.7 | AMP1-2: rgain=0 rgain_max=6400 2026-08-01 19:37:48 287.2 | AMP1: Channel0, gain_factor 6.1, gain_old=160, num=19 [ 1v 2v 4v 5v 8v 10v 16v 20v 32v 40v 50v 64v 80v 100v 160v 256 MAX! 320 MAX! 512 MAX! 1024 MAX!] 2026-08-01 19:37:48 287.2 | AMP1: Channel1, gain_factor 5.7, gain_old=160, num=19 [ 1v 2v 4v 5v 8v 10v 16v 20v 32v 40v 50v 64v 80v 100v 160v 256 MAX! 320 MAX! 512 MAX! 1024 MAX!] 2026-08-01 19:37:48 287.2 | AMP1: Ch1 -> DMA Pos. 1 2026-08-01 19:37:48 287.2 | AMP1: Ch2 -> DMA Pos. 2 2026-08-01 19:37:48 287.2 | -> Offset too high on Rank1, Trigger disabled! 2026-08-01 19:37:48 287.2 | -> Offset too high on Rank1, Trigger disabled! 2026-08-01 19:37:48 287.2 | AMP1-1: rgain=0 rgain_max=6400 2026-08-01 19:37:48 287.2 | AMP1-2: rgain=0 rgain_max=6400 2026-08-01 19:37:49 287.7 | AMP1: Ch1 -> DMA Pos. 1 2026-08-01 19:37:49 287.7 | AMP1: Ch2 -> DMA Pos. 2 2026-08-01 19:37:49 287.7 | -> Offset too high on Rank1, Trigger disabled! 2026-08-01 19:37:49 287.7 | -> Offset too high on Rank1, Trigger disabled! 2026-08-01 19:37:49 287.7 | AMP1-1: rgain=0 rgain_max=6400 2026-08-01 19:37:49 287.7 | AMP1-2: rgain=0 rgain_max=6400 2026-08-01 19:37:50 288.2 | AMP1: Ch1 -> DMA Pos. 1 2026-08-01 19:37:50 288.2 | AMP1: Ch2 -> DMA Pos. 2
