[REQUEST API/DATA USAGE] - Non-Commercial Personal Hobby Project - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org/mybb) +-- Forum: Public Forums (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=29) +--- Forum: Website, Maps and Applications (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=24) +--- Thread: [REQUEST API/DATA USAGE] - Non-Commercial Personal Hobby Project (/showthread.php?tid=4312) |
[REQUEST API/DATA USAGE] - Non-Commercial Personal Hobby Project - onurd - 2026-09-30 Hello, I am working on a very small personal hobby project related to local thunderstorm forecasts and live lightning activity, and I would like to ask whether my intended use of Blitzortung data would be acceptable. This is not a commercial product and I do not plan to monetize it. It will most likely remain a personal learning project used by myself and perhaps a few friends. I am not a professional software developer. I have been building the project mainly with the help of AI coding tools while learning about lightning detection, weather forecasting and geospatial processing. The project currently shows a simple local thunderstorm forecast. I would like to add a separate live-observation layer using Blitzortung data. The intended use would be limited to simple informational summaries such as: nearest recently detected lightning strike, number of recent detections within 10 / 25 / 50 km, time since the most recent nearby detection At a later stage, I may also experiment with non-authoritative trend wording such as “activity appears to be approaching” or “moving away,” based on recent strike patterns. I understand that this would only be an approximation and would not be presented as a storm track, safety guarantee, or official warning. I also understand that Blitzortung data must not be used as an official storm-warning or safety-critical system. The project would clearly state that it is informational only and that users should follow official meteorological and emergency guidance. Technically, I would not want every browser to connect directly to Blitzortung. If permitted, my preferred setup would be a single server-side connection, very short-term in-memory retention of recent detections (for example up to 60 minutes), and only derived proximity information shown to the user. Before proceeding, I would like to ask:
Thank you very much for your time and for maintaining such an interesting community project. RE: [REQUEST API/DATA USAGE] - Non-Commercial Personal Hobby Project - cutty - 2026-09-30 Blitzortung is not a general-purpose public lightning-data service or API provider. The network exists primarily for participating station operators and the cooperative lightning-location project itself. Its data is not offered as a general source for private applications, websites, hobby projects, research tools, AI-assisted projects, or other third-party services. Publicly available Blitzortung maps and related services may be used where appropriate. Direct access to the underlying lightning data is not provided for general third-party use. If your project requires a general source of lightning data for use in your own application or service, you should look to a provider whose purpose is to supply that type of data. |
