Request for lightning data - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org/mybb) +-- Forum: Public Forums (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=29) +--- Forum: Website, Maps and Applications (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=24) +--- Thread: Request for lightning data (/showthread.php?tid=4280) |
Request for lightning data - Alidigitaly - 2026-08-20 Request for limited real-time data access — Skycam Groningen / SkyHUD Hello, My name is Alex and I run Skycam Groningen, a personal, non-commercial live camera and weather project in Groningen, the Netherlands: https://skycam.alexfrankes.nl The livestream includes a custom HUD combining local weather information, rain radar, astronomical events and aircraft received by my own ADS-B receiver. I would like to ask whether Blitzortung could explicitly permit limited use of its real-time lightning data for this project. The lightning data would not be used to create another general-purpose lightning map. It would be integrated into the existing local SkyHUD:
To minimise server load and prevent misuse, the public HUD would never connect directly to Blitzortung. A small local relay on the stream computer would retrieve only the required data, filter and cache it, and provide a limited local JSON feed to the HUD. Blitzortung.org would be clearly credited on screen and in the stream information, for example: “Lightning data: Blitzortung.org — CC BY-SA 4.0” I would only need the timestamp, latitude and longitude of recent detections. Historical bulk data is not required. Would this project qualify for explicit permission to use the real-time data? If so, could you advise me which supported access method I should use? I would also be open to operating a Blitzortung receiver in Groningen if becoming a participant is the preferred route. Thank you for maintaining this remarkable volunteer network. Best regards, Alex Skycam Groningen |
