3D-Print-Enclosure for Ferrite Antenna - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org/mybb) +-- Forum: Public Forums (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=30) +--- Thread: 3D-Print-Enclosure for Ferrite Antenna (/showthread.php?tid=4263) |
3D-Print-Enclosure for Ferrite Antenna - ArneHude - 2026-07-31 Hi everyone, I wanted to briefly introduce you to my new DIY project: an outdoor enclosure for ferrite antennas, specifically designed for lightning detection stations. The model is now available for free: https://makerworld.com/de/models/3113734-blitzortung-ferrite-rod-antenna-outdoor-box The enclosure is designed so that ferrite rods can be mounted securely, weatherproof*, and with minimal vibration. Key features of my design: Modular design – ferrite rods can be quickly swapped out or reoriented Weatherproof* outer housing with optional sealing lips Internal structure to isolate against minor vibrations Easy to assemble – all parts are printable with minimal support structures Cable grommets for clean, protected cable routing I’m now using the enclosure myself at my station and am very satisfied with its stability. The * refers to the fact that the station is built with overlapping sections but does not include sealing rings, etc. More on this in the description. Question for the community: Is there interest in additional variants or alternative enclosure designs? Examples I’m already considering:
I’d design new variants directly in CAD and then make them available as printable models. I look forward to your feedback and suggestions for improvement! Best regards, Arne RE: 3D-Print-Enclosure for Ferrite Antenna - Eric.Wouters - 2026-07-31 great project for 3D printer lovers. BTW what is your station number ? You might change color
RE: 3D-Print-Enclosure for Ferrite Antenna - ArneHude - 2026-07-31 (3 hours ago)Eric.Wouters Wrote: great project for 3D printer lovers. 3276 ;-) |
