LightningMaps.org: Real-time Lightning Map - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org/mybb) +-- Forum: Public Forums (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=29) +--- Forum: Website, Maps and Applications (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=24) +--- Thread: LightningMaps.org: Real-time Lightning Map (/showthread.php?tid=464) |
RE: Real-time Lightning Map - Donald.Froula - 2014-07-15 The "Sent" statistic on the Controller Status page does NOT mean the signal was used in the calculation of a strike. In fact, the Controller firmware has no way of knowing that. I believed the "Received" count tracks the number of signals that exceeded their trigger threshold, plus signals from other channels that detected the same signal that caused the initial trigger. The "Sent" statistic counts the number of signals that triggered sending a report to the server, plus all other signals that exceeded the 10% of own threshold criteria (or whatever threshold is set in the "Settings/Tracker/Ignore signals below threshold" box), which causes those additional signals to actually be sent to the server, along with the triggering channel. For example, assume you have an H-Field and an E-Field amp. This provides channel 1A and 1B (H-Field) and 2A, 2B, and 2C (E-Field). All five channels are set to use a threshold of 120mV. "Settings/Tracker/Ignore signals below threshold" is set to the default 10%. A signal that exceeds 120mV is detected by channel 1A. Energy is detected from the same signal on channels 1B and 2A, 2B and 2C. Therefore, the strike will cause the "Received" count on the Status page to increase by 5. The amplitudes of the additional channels are: 1B - 60mV (exceeds 10% of 120mV or 12 mV, so the signal is sent to the server as well as the triggering signal on 1A) 2A - 8mV (does NOT exceed 10% of 120mV or 12 mV, so that signal is NOT sent to the server) 2B - 6mV (does NOT exceed 10% of 120mV or 12 mV, so that signal is NOT sent to the server) 2C - 40mV (exceeds 10% of 120mV or 12 mV, so the signal is sent to the server as well as the triggering signal on 1A) So, in this case, the number of "Sent" signals is 3, so the "Sent" count on the Status page will only be increased by 3. The fact that a signal is "Sent" from the Controller's perspective only means that the criteria for sending a received signal to the servers has been met. It says nothing about whether those signals are actually used in the calculation of a valid strike. In fact, the "Sent" signals could all be generated by noise, and still meet the criteria for transmission to the server. Setting the "Settings/Tracker/Ignore signals below threshold" value to 100% will insure that only signals that exceed 120mV will be sent. There are other gating criteria that are used to determine if ANY signals are sent, like having an active network connection and a good GPS lock. You will note that after a system is powered on, the signal count will increase, but none of the signals are counted as "Good" or "Sent" until a GPS lock is achieved. If the system works otherwise, one of the developers, please, jump in here and correct me. Best regards, Don WD9DMP (2014-07-15, 17:19)Asbjorn.Aamot Wrote:(2014-07-14, 23:31)Cutty Wrote: A beep does not mean a valid, or a usable 'stroke'. It beeps on any signal, noise, car, pet fence, switch, etc that causes a trigger.... If you're not seeing signals on the Participants page, or low values, or not seeing them on the map, it could mean that most of your signals are noise. RE: Real-time Lightning Map - Tobi - 2014-07-16 (2014-07-14, 23:29)HolzHaus Wrote: i did a quick video that show how i looks on a android tabletWhat exactly do you want to show us with this video? RE: Real-time Lightning Map - HolzHaus - 2014-07-16 (2014-07-16, 10:47)Tobi Wrote:(2014-07-14, 23:29)HolzHaus Wrote: i did a quick video that show how i looks on a android tabletWhat exactly do you want to show us with this video? im stormchaser and i use realtime map for chasing. The issues nerven sometimes, just want to show how it looks on a real device, not on a emulator
RE: Real-time Lightning Map - Tobi - 2014-07-16 Which issues? RE: Real-time Lightning Map - ari.jasberg - 2014-07-19 Great work, thanx ![]() On my Windows Phone 8.1 (Lumia 625), I cannot pan or pinch-to-zoom the map with gestures, those will be captured by the main window, not the map interface. I have tested a few different browsers, but the problem remains. I guess this behavior is caused by a bug in WP operating system that has been known for some time, and I am pessimistic about ms correcting it . However, there may be some workarounds. Do you have this issue on your todo list?Ari R: RE: Real-time Lightning Map - jumpjack - 2014-07-20 (2014-07-19, 14:54)ari.jasberg Wrote: Great work, thanxI think it depends on browser or page, as it happens to me in chrome for android on some internet pages. Blitzortung realtime map works fine. RE: Real-time Lightning Map - AleT - 2014-07-25 (2014-06-20, 15:44)Tobi Wrote: Due to some requests, there's now a view which visualizes speed of (thunder-)sound on high zoom levels. I don't know if it's a problem with my browser (chrome on Win7) but the speed of sound seems to be about five times too high. I crudely measured your thunder rings expanding at about 1.5km per second rather than the .3Km/s I would have expected. EDIT: I measured it on another PC, and the speed is now correct. So either I have a problem with my original PC, this has been fixed over the last week, or I just measured it wrong! Thanks. Suggestion: lightning rate - Jonathan.Williams - 2014-08-19 On the lightning map, we currently have the delay displayed in the upper left hand corner. Would it be possible to add a realtime, region-specific or displayed area-specific strike rate (strikes/second), too? RE: LightningMaps.org: Real-time Lightning Map - Tobi - 2014-08-20 A new version of the map is online. There are still some minor bugs. The code has been completely rewritten which makes it easier to add new features. Stay tuned...
RE: LightningMaps.org: Real-time Lightning Map - Tobi - 2014-08-22 Rain radar for USA has been added as additional overlay!
