Robotic lawnmower interference? - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org/mybb) +-- Forum: Public Forums (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=30) +--- Thread: Robotic lawnmower interference? (/showthread.php?tid=705) |
RE: Robotic lawnmower interference? - mekhall - 2014-08-23 (2014-08-23, 08:51)Benedict.Smith Wrote:(2014-07-31, 20:57)mekhall Wrote: Are there any measurements I can do to see how large and what kind of interference my Husqvarna mower produces? I have a cheapish oscilloscope and a nice multimeter... Ok, that sounds interesting - I will build a loop antenna and connect it to the scope (as I do not yet have a Blitzortung system). RE: Interference with Husqvarna Automower - BobW - 2014-09-02 (2014-06-22, 10:49)GeigerBe Wrote: Hello, I have a question about these mowers. Has anyone figured out what specific frequency that the wire radiates on? It would seem that it might be possible to help the mower "get lost" by running a parallel wire to the neighbors and inducing a "slightly higher" on frequency signal into the "other" wire. Enough jumps of the boundary, and subsequent ending of mowing, and they might give up. Wouldn't want to do this with a dog containment fence, but if the lawn mower were to escape......Here in the US, there are very few manufacturer's selling those, and Husqvarna's web site lists no dealers of theirs here. If they did show up here, they'd have to get FCC authorization - which they haven't yet - For you global guys, the FCC is a good place to get more information about things that are sold in the US, and internal pictures too. For example, put "kz3" in the grantee code box, and you get a bunch of info on dog containment fences made by one company that operate on 10.7 khz. That IS considered RF in the US. RE: Robotic lawnmower interference? - petterfs - 2020-04-21 Station 2691: This is an old thread, but yesterday at around 18:00 I took the Automower out of hibernation and placed it in the charging station. As I wanted to check the blitzortung system and it indicated that it had been in interference mode since around 18:00 yesterday. I have both 3x ferrite antennas and an E-field antenna placed approx 8 meters above ground. It seems that I have to a) design a relay switch on the fence wire and/or b) set the gain manually in the blitzortung station... RE: Robotic lawnmower interference? - mwaters - 2020-04-22 (2020-04-21, 20:33)petterfs Wrote: Station 2691: Have you gone into the Settings and enabled Auto Amplitude Filter? That helps eliminate RFI from robotic lawn mowers. RE: Robotic lawnmower interference? - petterfs - 2020-04-27 (2020-04-22, 04:31)mwaters Wrote:(2020-04-21, 20:33)petterfs Wrote: Station 2691: Yes, I tried that, but it did not help. Contacted Husquarna today, and got an answer that if ECO-mode is enabled in the Auotmower, the loop will bed powered off during charging. Will test when I get home today. RE: Robotic lawnmower interference? - petterfs - 2020-04-27 Result after a little testing: 1. Enable "Eco mode" under settings in the Automower. 2. Start mowing (or press start at set start next day). This seems to be when the setting for Eco mode is saved. With the settings "Automatic, Noise adaption, Amplitude filter" Signals are approx 800mV p-p with the Automower loop active (Eco mode off), while with eco mode on (the Auomower loop inactive), the signal (noise floor) is approx. 75mV p-p Ideal fix: 1. Install a relay/contactor to disconnect the loop in case a thunderstorm gets near 2. Install a relay/contactro to disconnect the power supply to the Automower 3. Log when the Automower starts to cut, automatically setting the blitzortung receiver to manual mode with a predefined set of settings. 4. Return to automatic settings as soon as the Automower is finished cutting. 5. Integrate all of the above in the Loxone smart home Signal without Eco mode enabled: Signals WITH ECO mode enabled (or with the automower charging station disconnected from power supply): RE: Robotic lawnmower interference? - OH4GRM - 2020-05-31 You can use IFTTT to trigger parking of Husqvarna Automower when it is raining. Then having ECO setting on it turns fencing lines off as it is parked. |
