Housing for System Blue (laser cut/3d print) - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org/mybb) +-- Forum: Public Forums (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=30) +--- Thread: Housing for System Blue (laser cut/3d print) (/showthread.php?tid=2462) |
RE: Housing for System Blue (laser cut/3d print) - wbkkwx - 2018-04-12 looks good in transparent acrylic! RE: Housing for System Blue (laser cut/3d print) - cutty - 2018-04-12
RE: Housing for System Blue (laser cut/3d print) - readbueno - 2018-04-13 I think the aluminium housing provides some shielding from the various sources of noise that we all have about us and I consider it a backward step to remove this added protection! Brian. 1856 Vilaboa
RE: Housing for System Blue (laser cut/3d print) - mwaters - 2018-04-13 (2018-04-13, 22:09)readbueno Wrote: I think the aluminium housing provides some shielding from the various sources of noise that we all have about us and I consider it a backward step to remove this added protection! What tests have you performed to prove that, Brian?
RE: Housing for System Blue (laser cut/3d print) - cutty - 2018-04-14 (2018-04-13, 22:14)mwaters Wrote:(2018-04-13, 22:09)readbueno Wrote: I think the aluminium housing provides some shielding from the various sources of noise that we all have about us and I consider it a backward step to remove this added protection! Brian, if that were necessarily the case, do you really believe I would have my "Blitz Wall' configured as in the above image, within inches of 3 large monitor screens, and within two meters of 5 operating PC Towers, routers, modems etc???? ![]() In this situation, my junk is H field Antenna, received noise... the Controllers, and E amplifer for the Reds just quietly do their thing. RE: Housing for System Blue (laser cut/3d print) - mwaters - 2018-04-14 My thinking exactly! Those 3 stations are performing superbly without any shielding whatsoever! RE: Housing for System Blue (laser cut/3d print) - readbueno - 2018-04-14 O.K. Folk's! I know absolutely nothing I am just another grumpy old fool! Forgive/ignore my input/intrusion into this topic. My profuse apologies! We can all believe what we want to, but that does not make it true? Intuitively, if a electronic circuit has a metal case, it is better shielded than the same circuit without that case? Maybe, you have just got the settings correct to cover/mask any bad effects? Kindest regards, Brian. 1856 Vilaboa. P.S. I am never right in any of the forums that I post in! Even, when I agree with people, there is always someone that wants to disagree. I am too old to fight. So, just ignore me and I will fade into the background gracefully.
RE: Housing for System Blue (laser cut/3d print) - PeterTim - 2018-04-14 (2018-04-14, 08:11)readbueno Wrote: O.K. Folk's! I know absolutely nothing I am just another grumpy old fool! Is the used alu house grounded? I ll think that if you use the ground as provided, and connect it to the print provided it would be ok. Otherwise you should make use of the cage of Faraday so you will need to ground th ehousing - if you ask me - But hey who am I?b
RE: Housing for System Blue (laser cut/3d print) - wsttdb - 2018-05-06 I don't have a laser cutter, but I do have a 3d printer, so I'm making one that I'll be posting to thingiverse when complete.
RE: Housing for System Blue (laser cut/3d print) - fpatt-1 - 2018-09-03 (2018-01-08, 01:13)higherperspective Wrote: Hi all. Hi all, about the system blue housing. Does anyone has pdf files on the front and back panel from the aluminum box. In the hardware index you only find TARGET 3000 files, but my system (MAC) can not read those files. The files can be found here: http://de.blitzortung.org/Compendium/Hardware/. Thanks in advance! |
