Threads: 7
(2014-06-07, 14:51)Tobi Wrote: Here's what I've written in the internal forum:
(2014-05-17, 06:51)Tobi Wrote: For privacy reasons the station coordinates on the map are rounded. There's no reason to see the exact position on this map, so I the stations are now hidden on higher zoom level.
It's just a compromise. We can also add an option for participants to show the exact coordinates of their stations to the public...
It is not necessary for me, I'm just wondering....
Threads: 1
if i run the realtime map on my iPad 3 (iOS 7.1.1), after several minutes the safari is crashing (closing).
NosDE
Threads: 9
(2014-06-09, 20:08)NosDE Wrote: Hi,
NosDE
It does the same on mine with iOs 6.1.2, FR24 also does the same, safari is not very stable on iOS and crashes if the data rate is too high.
Ben.
NB it works fine on the iMac.
RED Station: 878, Flightradar24: F-EGLF1, Open Glider Network: Aldersht2, PlanePlotter: M7.
Stations: 878
Threads: 75
NosDE
We already investigating this problem. It seems, it happens due to a bug in iOS 7 in combination with GoogleMaps. There seem to be other projects which have similar problems.
Threads: 1
2014-06-10, 10:39
(This post was last modified: 2014-06-10, 11:12 by NosDE.)
Hi Tobi,
i think safari did consume too much memory due to the number of placemarks (strikes) that have to be rendered into the map.
This exist on iPhone 5s with iOS 7.1.1 and iPhone 4 with iOS 6.1.3 too.
A possible solution temporalily solution could be, to render only strikes on the map, that are in the bounds of current view.
A second approach could be, to limit the time, that a strike is placed on the map.
-NosDE
Threads: 19
(2014-06-10, 10:14)Tobi Wrote: There seem to be other projects which have similar problems.
The problem i have runned over with my own maps is that browsers starts to crash/slow down when the amount of markers (strikes) reach x amount. This level varys a bit between the browsers but from my tests are it somewhere between 1000 and 2000 markers. The only way to get around this is to limit the amount of shown markers to say 1500.
// Henkka
Threads: 1
That is what i want to say
The strikes on the map should be limited. When the limit is reached (user selectable) the oldest strikes should be removed from map.
-NosDE
Threads: 75
The markers are already limited to a few hundred.
Threads: 19
(2014-06-10, 18:17)Tobi Wrote: The markers are already limited to a few hundred.
OK. Then its probably the animations and the recoloring of the markers what cause it. From what i have noted its fully possible such things needs to be forced shut off in (some of) the mobile browsers before things starts to work smoothly. I know, its a cool feature but i have runned over similar things with my own maps too, its a never-ending compromise between the coolness and core functionality.
// Henkka
Threads: 75
All those animations and effects were already very limited on the mobile style. Since yesterday they are even more reduced. However, some animation is needed, otherwise you wouldn't see new strikes popping up and the real time map would be useless. So far we didn't experience much crashes any more on iDevices, but maybe that's also due to the lower strike rates now.
BTW: An own app would be great, but so far nobody want to write an official app for us. We could do it too, but there's no time for that.
Threads: 1
@Tobi
i can give it a try. Where i can find needed Specs about Webservice ?
NosDE (Marco)
Threads: 75
(2014-06-11, 19:29)NosDE Wrote: Where i can find needed Specs about Webservice ? Sorry, but there are currently no specs and no webservice. We are working on it, but it will take some longer time due to high amount of work.
Threads: 1
(2014-06-11, 19:51)Tobi Wrote: (2014-06-11, 19:29)NosDE Wrote: Where i can find needed Specs about Webservice ? Sorry, but there are currently no specs and no webservice. We are working on it, but it will take some longer time due to high amount of work.
Problem is not solved yet.
Attached parts of report:
Quote:Hardware Model: iPad3,3
OS Version: iPhone OS 7.1.1 (11D201)
Kernel Version: Darwin Kernel Version 14.0.0: Fri Mar 28 21:15:11 PDT 2014; root:xnu-2423.10.70~1/RELEASE_ARM_S5L8945X
Date: 2014-06-11 23:40:57 +0200
Time since snapshot: 61 ms
Free pages: 2150
Active pages: 7357
Inactive pages: 3489
Speculative pages: 534
Throttled pages: 183615
Purgeable pages: 0
Wired pages: 55960
File-backed pages: 11023
Anonymous pages: 357
Compressions: 1062526
Decompressions: 252476
Compressor Size: 135
Uncompressed Pages in Compressor: 122
Largest process: Web
Processes
Name <UUID> rpages recent_max fds [reason] (state)
EscrowSecurityAl <78bed6be170e3270a13630acb6ce976f> 170 170 100 [vm-pageshortage] (daemon)
MobileMail <3f0ef8f605de310e9b97b9a482f41e44> 1280 1280 100 [vm-pageshortage] (resume) (continuous)
tccd <1abc957a1c7d3a5da04ef097be7b6c5f> 157 157 100 [vm-pageshortage] (daemon)
kbd <f6a047c5fa473e5c89c451ac1750c84a> 1202 1202 100 [vm-pageshortage] (daemon)
Web <0eee4f489be83c29955d7f07690691e6> 171477 171477 100 [vm-pageshortage] (frontmost) (resume)
NosDE
Threads: 0
As far as running it on a PC is concerned it runs extremely smoothly on firefox 29
I notice though that a link on the blitzortung.org page has been removed.
vooliberista
Threads: 17
2014-06-14, 21:29
(This post was last modified: 2014-06-14, 21:33 by W3DRM.)
My Android phone shows the Live Maps display nicely and scales everything correctly. However, I do not see any new strikes at all. The Live Data indicator is flashing yellow very rapidly. The Background Map indicator is green and all of the selectors (Strikes, Detectors & Sound) have a check-mark in them.
I'm running on a Samsung Galaxy S3 using the default web browser on the phone. My connection is via my home wi-fi.
Any ideas what may be wrong? This is the first time I have tried to view the BO live map on my Android phone so don't know if it may be some setting I am missing or not.
Threads: 62
2014-06-14, 21:39
(This post was last modified: 2014-06-14, 21:40 by cutty.)
(2014-06-14, 21:29)W3DRM Wrote: My Android phone shows the Live Maps display nicely and scales everything correctly. However, I do not see any new strikes at all. The Live Data indicator is flashing yellow very rapidly. The Background Map indicator is green and all of the selectors (Strikes, Detectors & Sound) have a check-mark in them.
Any ideas what may be wrong? This is the first time I have tried to view the BO live map on my Android phone so don't know if it may be some setting I am missing or not. Don, My HTC G3 does fine on Lightningmaps.org realtime... on BO realtime, error "socket not supported by your browser..." no real-time.
Threads: 17
2014-06-14, 21:45
(This post was last modified: 2014-06-14, 21:53 by W3DRM.)
(2014-06-14, 21:39)Cutty Wrote: (2014-06-14, 21:29)W3DRM Wrote: My Android phone shows the Live Maps display nicely and scales everything correctly. However, I do not see any new strikes at all. The Live Data indicator is flashing yellow very rapidly. The Background Map indicator is green and all of the selectors (Strikes, Detectors & Sound) have a check-mark in them.
Thanks Mike. Same issue on my S3. However, I do not hear the clicks on Lightningmaps.org. The note indicates it may not be available on all devices.
I'm downloading Google Chrome to see if it works any better.
(2014-06-14, 21:45)W3DRM Wrote: (2014-06-14, 21:39)Cutty Wrote: (2014-06-14, 21:29)W3DRM Wrote: My Android phone shows the Live Maps display nicely and scales everything correctly. However, I do not see any new strikes at all. The Live Data indicator is flashing yellow very rapidly. The Background Map indicator is green and all of the selectors (Strikes, Detectors & Sound) have a check-mark in them.
Works fine with Chrome but still no audio. Seems to load and run faster than with the default browser on my S3.
Threads: 75
(2014-06-14, 21:29)W3DRM Wrote: Any ideas what may be wrong? This is the first time I have tried to view the BO live map on my Android phone so don't know if it may be some setting I am missing or not. Don't know what's going wrong. We've tested with an Android phone and emulators and found no problems so far.
Threads: 17
(2014-06-14, 21:53)Tobi Wrote: (2014-06-14, 21:29)W3DRM Wrote: Any ideas what may be wrong? This is the first time I have tried to view the BO live map on my Android phone so don't know if it may be some setting I am missing or not. Don't know what's going wrong. We've tested with an Android phone and emulators and found no problems so far.
Hi Tobi, as I mentioned above, it is now working fine with the Google Chrome browser but no audio. Audio works fine on other websites so not sure what may be wrong. This is really a great viewer. You've done a superb job putting all of this together.
I can't thank you enough for everything you and the others have done.
Threads: 1
2014-06-14, 22:02
(This post was last modified: 2014-06-14, 22:03 by NosDE.)
Tobi,
today no crash on iOS - scary, or did you solved something ?
I think it is really time, to go native on i Devices.
-NosDE
