dashed green lines appearing on page ( /en/live_lightning_maps.php
Sorry if this is posted somewhere already.  A forum search for "dashed" and/or "green" is not providing an answer.
What are the straight, green dashed lines showing up on the page  https://www.blitzortung.org/en/live_lightning_maps.php  ?
They are often intercontinental but don't seem to show up with every strike.
In the center of the circle there is a recent stroke and the dashed green lines connect it to the stations that detected it.
You may want to use this map instead. It is much more flexible. You can pan and zoom. Also check out the icon with the three horizontal lines. It allows detailed configuration.
https://map.blitzortung.org/#2.07/36.8/-7.38
(2024-08-16, 02:36)Reverberocket Wrote: Sorry if this is posted somewhere already.  A forum search for "dashed" and/or "green" is not providing an answer.
(2024-08-16, 06:01)gerbold Wrote: In the center of the circle there is a recent stroke and the dashed green lines connect it to the stations that detected it.
also:  Rolleyes HINT:
[Image: map.png]
Perfect - thank you.
  lines chasbrand 1 24,310 2014-07-02, 16:27
