How to set city and country 2725
I did not manage to set city and country, is it done internally in the detector or externally on the web? I once got into these settings along with settings for types of antennae. Filled in the values ands saved them, but they did not turn up in the map. Cannot get back to the site where I am supposed to register the data.
I am also not able to log in to the forum for participants.
Login with username and password here: http://en.blitzortung.org/login.php. There you can set city and country.
Recently I learned the username turns green only once the station has sent it's first data. I'd assume entering the participants part of the forum is related to the user name turning green.
Stations: 2065, 2398, 2729
(2020-06-23, 20:06)gerbold Wrote: Login with username and password here: http://en.blitzortung.org/login.php. There you can set city and country.
Thank you very much, it solved my problems as you can see on the map.
  I wanna host antennas on rooftop of 12 stages house in centre of city Thak1974 3 796 2024-03-18, 11:10
