Error in PCB_20_7
When open directory "Index of /Compendium/Hardware/PCB_20_7/" , we see same file                               05-Mar-2020 15:35              94992
 .   If I uderstand right this files must be different.
Hi aeromash,
you are right 16_2 should be the E-field pre-amp with just one channel. Refer to HW 20_6.
Please remove the links to the internal documents from the public forum.
Thanks
Klaus
Stations: 2065, 2398, 2729
(2020-06-12, 06:12)aeromash Wrote: When open directory "Index of /Compendium/Hardware/PCB_20_7/" , we see same file                               05-Mar-2020 15:35              94992
Yes, you are right.
/Egon
Stations: 2656, 3044
(2020-06-13, 04:19)gerbold Wrote: Hi aeromash,
Thanks
Klaus
But the link to the schematics is already public on the main website.
Look in the section:
https://www.blitzortung.org/en/cover_your_area.php
Then follow the link to 'Assembly Instructions System Blue'.  In section 2.2 the link is right there.
