how to change status to participant
I'm a participant (station 2441, user1905). I used to be subscribed as participant but now seem to be as a registered member. How do I change forum  status to participant?
One of the admins will see this and help you. Probably Cutty will do it.
Station: 2677
The Vines Weather
Stations: 2677
Done!  Welcome aboard!
Same here! I'm a participant for station 2410, user 1887
I never had a participant status
Pomacaja, you are now set.
I have station 2733 active, but nut participant status.
Hello !
I am a participant (station 2401 user 1880) and my profile on the forum only shows that I am registered as a member of the forum !!! how to change status?
Thank you for your help. Undecided
(2020-06-30, 08:19)MTO-Mareuil Wrote: Hello !
you're updated... (no need to shout... Big Grin )
thank you so much !!! Tongue
Dear all,
Greetings from Bulgaria. Just became a participant (thanks, Egon!). My first Station ID is 2757 and my User ID is 2114. Can you please change my status to "Participant". Thanks in advance!
Kind Regards,
Koleto
Cloud Stations: 2757, 2776
(2020-07-20, 19:12)koleto Wrote: Dear all,
Kind Regards,
  Koleto
Status has been changed.
Welcome! You can change your signature by following the simple instructions at https://forum.blitzortung.org/showthread...0#pid21490.
Thanks, Mike! My signature is now updated.
Hello !
I am a participant (station 2764 user 2146) and my profile on the forum only shows that I am registered, how to change status to participant.
(2020-07-29, 01:24)scadie Wrote: Hello !
Status updated
Hi!
I have de same problem
Station ID 2782
User-ID: 2155
Thanks!
Mauro
(2020-08-20, 19:05)m.sedrani Wrote: Hi!
Station ID 2782
User-ID: 2155
Thanks!
Mauro
there you go
please do correct the settings for your station  (type of antenna etc) as this will influence your signal processing.
Stations: 1476
https://forum.blitzortung.org/showthread.php?tid=2764 ("Station Isn't Recognized. Not on List. ETC") is the correct thread for this, and the OP here should have been redirected to it.
Egon and the moderators will see it quicker if you post it there. Please read Cutty's instructions at the top first.
I suggest that this thread be locked.
Station ID 2782
User-ID: 2155
Thanks!
Mauro
there you go
The station has just been assembled and the antennas have not yet been connected.
I will update the data as soon as I have finished the initial setup.
Thanks!
(2020-08-20, 19:23)mwaters Wrote: https://forum.blitzortung.org/showthread.php?tid=2764 ("Station Isn't Recognized. Not on List. ETC") is the correct thread for this, and the OP here should have been redirected to it.
Thanks for the info.
  Participant status tkerby 2 3,906 2023-01-28, 17:16
Last Post: tkerby
  Getting Participant status. Not sure what I'm doing wrong. michidragon 15 60,701 2018-10-14, 03:05
Last Post: neil9
  Become a participant sunwind 4 21,098 2018-08-08, 23:21
Last Post: kevinmcc
