System Blue - H-field pre-amplifier
Hi All,
I would like to know what kind of CAT5 cable I should use between the H-Field pre-amplifier board and the mainboard. Is it a crossover cable or straight through cable?
Thanks
Best regards
David
Connect an H-field or E-field preamplifier to the board. On the connected preamplifiers the red LEDs should be on. If this is not the case, something is wrong with the connection cable. Use normal CAT cable. It must not be a crossed cable. Smile
It must also be shielded. The types are listed in the instructions.
(2019-08-21, 16:36)mwaters Wrote: It must also be shielded. The types are listed in the instructions.
Yes,
can anyone share wiring diagram of the cable, just to make sure that the connections are correct?
thanks
Yes,
thanks
It is a standard straight thru Ethernet cable.
  System Blue H-field only gmiller43 4 3,397 2026-05-13, 20:36
Last Post: MarkoFlow
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 50,867 2025-04-19, 23:25
Last Post: DrFX
Photo Turn-key System Red For Sale - H-Field and E-Field - SOLD Donald.Froula 2 19,983 2021-09-24, 16:06
Last Post: Donald.Froula
  H-field pre-amplifier placement inside loops? MDMD 2 27,396 2016-10-31, 16:29
Last Post: allsorts
  Wanted Pre-Amplifier 14 PCB and Amplifier Kit (Red) Michael1976 0 15,962 2016-07-26, 17:55
Last Post: Michael1976
