Hello, could I get upgraded to participant status?
User ID: 1978
Station ID: 2545
User ID: uovgaz
Region: North America 1/2
Thanks!
Station was recognized yesterday, missing from station list today
User name: SA2CLC
UserID : 2353
Station ID 2969
Location, Sweden
//Tommy
Stations: 2969
(2023-05-30, 19:16)SA2CLC Wrote: Station was recognized yesterday, missing from station list today
User name: SA2CLC
UserID : 2353
Station ID 2969
Location, Sweden
//Tommy
Your station is listed with no issues on Blitzortung.0rg  Servers Europe 1, 2, and 3.
Today I launched my own builded station. Can I get upgrade to participant rank on forum?
Username: maciejhka
user number: 2363
station number: 2992
Region: Europe, Poland
Thank you
Station: 2992
Stations: 2992
Hello,I can't find my station in station list.
User Name: BruceBob
Station Number: 2994
User ID: 2364
Region: Asia
BruceBob
Stations: 2994
IanL01
Station 1559
LightingMaps.org
Duplicate stations seen
Going from the link in the device
https://www.lightningmaps.org/blitzortun...o_sid=1559
Shows station active Yes
Pages shows a link other station for this user 1559
select that link
goto
https://www.lightningmaps.org/blitzortun...ion_id=117
Shows Station active yes/no reception. Last detected stroke 2021-03-02
Comment field updates if I change in Blizortung.org
Stations: 1559
(2023-07-04, 23:05)IanL01 Wrote: IanL01
Station 1559
LightingMaps.org
select that link
goto
Usually this happens when a station as been off-line at the last Blitzortung update, the last time Tobi synced LMO with Blitzortung (which are being constantly revised) you would be out of sync in the LMO listings. Note that Blitzortung is revising 'reporting region' assignments and other parameters. You want to use the tools available on the Blitzortung site,
Your station 1559 is currently assigned to report strikes in 4 region servers, which Lightningmaps does not read, as yet.
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
(2023-06-29, 01:11)brucebob Wrote: Hello,I can't find my station in station list.
User Name: BruceBob
User ID: 2364
Region: Asia
BruceBob
BruceBob...
1 .  IF your station hasn't actually sent signals, it will NOT activate on Blitzortung database.
2.   IF your station isn't configured properly on the Blitzortung Operator's page,
        SPECIFICALLY if "anonym" is 'Y', than your station won't display.  Make 'anonymous' = N for 'No'.
Station 1559
LightingMaps.org
select that link
goto
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
Thanks for the update. So its just a matter of waiting for the assignment to be updated/revised and a sync to take place, is that correct.
Stations: 1559
Station 1559
LightingMaps.org
select that link
goto
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
This thread is for the stations list on the parent Blitzortuung.org -- the actual computing platform.   Your are listed correctly there.  I cannot speak for when Tobi will restructure and sync the adjunct Lightningmaps.org.  See this reply re map data:
https://forum.blitzortung.org/showthread...0#pid25170
(2023-07-05, 13:25)cutty Wrote: Usually this happens when a station as been off-line at the last Blitzortung update, the last time Tobi synced LMO with Blitzortung (which are being constantly revised) you would be out of sync in the LMO listings. Note that Blitzortung is revising 'reporting region' assignments and other parameters. You want to use the tools available on the Blitzortung site,
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
This thread is for listings on the Main Blitzortung.org servers, NOT lightningmaps.org, so I cannot speak to when Tobii will re-address, for the umpteenth time, the databases and processing on the adjunct lightningmaps.org. He wisely isn't updating all/many of the databases and processes etc, with all the revisions going on with the Blitzortung regional computing servers... un-necessary work until Egon finalizes all the modifications... . For example, the network now computes to a very large number of 'regional' signal/stroke assignments, LMO basically assigning to only 3, awaiting stabilization of new definitions, etc.  I suggest you use and review the official data available on the 'official' site.
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
Stations: 1559
  Station List not showing any United Kingdom stations dgoadby 2 13,451 2019-04-15, 16:35
Last Post: dgoadby
  Removing Station 723 from list Ian.Cooke 5 30,270 2015-02-03, 20:39
Last Post: Toxic
Users browsing this thread: xpl012, 4 Guest(s)
