2020-10-15, 08:47
user name = stuiow
station number = 2821
region = Europe (UK)
2020-10-15, 08:47
user name = stuiow
station number = 2821 region = Europe (UK)
2020-10-15, 10:45
Another one:
Forum name jonfear Station number 2831 Region UK, Europe. Cheers!
2020-10-17, 23:19
User Name for Forum : Gruff 1973
Station Number if you have one: None allocated, 3900-3D00-1551-3833-3036-3138 Region... (Europe, Asia, etc...) : europe, UK Specify specific... don't enter a lot of comments... just the facts, please.... 'station not listed': Not Listed Forum operator status not upgraded,: Not Upgraded Station Number NOT associated with my User ID...: yes, not associated THanks for any help you can give
2020-10-18, 21:29
(2020-10-17, 23:19)Gruff1973 Wrote: User Name for Forum : Gruff 1973 If the Staton does not have a number, then it has not yet connected to the server on the Internet. The station must be connected to the Internet, otherwise it won't work. Since you were able to read out the processor ID, I assume that the station can be reached in the local network. /Egon
2020-10-20, 09:16
(2020-10-18, 21:29)Egon Wrote:(2020-10-17, 23:19)Gruff1973 Wrote: User Name for Forum : Gruff 1973
2020-10-20, 20:03
User: sm7ugo
Station Number 2737 Region: Europe Forum operator status not upgraded.
2020-10-21, 18:59
Hi, is this post still being monitored?
2020-10-21, 21:17
(2020-10-21, 21:17)dupreezd Wrote:Ok. Thanks.(2020-10-21, 18:59)SGJones Wrote: Hi, is this post still being monitored?Your status is already changed to Participant. I still get “station ID not recognised” when I try to enter it on the web page, and I can’t see it on the station list. Maybe I need to understand more.....?
2020-10-31, 12:46
User name: yVega
User number: 2207 Station number: ? Region: Europe I'm online now, how can I get the associated station number?
2020-10-31, 12:57
(2020-10-31, 12:46)yVega Wrote: User name: yVegaHave you registered your station on the owner's page? If in fact your station has sent signals to the server, it should be recognized, and on your controller page, upper right, should show a number, or instruction link to register. under 'tracker' status, should show a server connection and address.... the system WILL not recognize you IF YOU HAVE NOT sent signals.
2020-10-31, 13:00
(2020-10-31, 12:57)cutty Wrote:(2020-10-31, 12:46)yVega Wrote: User name: yVegaHave you registered your station on the owner's page? If in fact your station has sent signals to the server, it should be recognized, and on your controller page, upper right, should show a number, or instruction link to register. under 'tracker' status, should show a server connection and address.... the system WILL not recognize you IF YOU HAVE NOT sent signals. AND and the system WON'T become active at all unless good GPS is noted, and 1PPS signal syncs. (2020-10-31, 13:00)cutty Wrote:Sorry, I had activated the system with network/gps online only...(2020-10-31, 12:57)cutty Wrote:(2020-10-31, 12:46)yVega Wrote: User name: yVegaHave you registered your station on the owner's page? If in fact your station has sent signals to the server, it should be recognized, and on your controller page, upper right, should show a number, or instruction link to register. under 'tracker' status, should show a server connection and address.... the system WILL not recognize you IF YOU HAVE NOT sent signals. AND and the system WON'T become active at all unless good GPS is noted, and 1PPS signal syncs. where I can read the Processor-ID for insert then in owner page? and where can I read the sequences of operations I have to do? I would not forget anything else
2020-10-31, 17:12
(2020-10-31, 14:52)yVega Wrote: where I can read the Processor-ID for insert then in owner page? Please see https://forum.blitzortung.org/showthread...d#pid20250
2020-10-31, 22:32
(2020-10-31, 17:12)mwaters Wrote:Ok, thanks for your patient, it's all associated now.. tomorrow I'll position better primary antenna and gps antenna(2020-10-31, 14:52)yVega Wrote: where I can read the Processor-ID for insert then in owner page?
2020-10-31, 22:39
(2020-10-31, 22:32)yVega Wrote:yVega, what is your station number so we can have a look at it and move you to Participant status if you are sending signals.(2020-10-31, 17:12)mwaters Wrote:Ok, thanks for your patient, it's all associated now.. tomorrow I'll position better primary antenna and gps antenna(2020-10-31, 14:52)yVega Wrote: where I can read the Processor-ID for insert then in owner page? (2020-10-31, 22:39)dupreezd Wrote:Sorry, I'm updating request:(2020-10-31, 22:32)yVega Wrote:yVega, what is your station number so we can have a look at it and move you to Participant status if you are sending signals.(2020-10-31, 17:12)mwaters Wrote:Ok, thanks for your patient, it's all associated now.. tomorrow I'll position better primary antenna and gps antenna(2020-10-31, 14:52)yVega Wrote: where I can read the Processor-ID for insert then in owner page? User name: yVega User number: 2207 Station number: 2855 Region: Europe
2020-11-02, 23:34
(This post was last modified: 2020-11-02, 23:35 by Dave:WD7K.
Edit Reason: added user name
User Name: Dave:WD7K
User Number: 1780 Station Number: 2283 Region: North America Station listed, Was receiving data. No longer receiving data. (2020-10-31, 17:12)mwaters Wrote:You won't need to insert processor ID... if you have sent signals, and server has activated your station, the server knows it already, assuming it is associated with your user ID. What you WILL have to do is input the correct antenna configuration, and, if you want it's data displayed on maps, etc, make sure "ANON" is "NO"...(2020-10-31, 14:52)yVega Wrote: where I can read the Processor-ID for insert then in owner page? (2020-11-03, 12:34)cutty Wrote:(2020-10-31, 17:12)mwaters Wrote:You probably won't need to insert processor ID... unless you've taken over a station previously assigned to someone else,... if you have sent signals, and server has activated your station, the server knows it already, assuming it is associated with your user ID. What you WILL have to do is input the correct antenna configuration, and, if you want its data displayed on maps, etc, make sure "ANON" is "NO"...(2020-10-31, 14:52)yVega Wrote: where I can read the Processor-ID for insert then in owner page? |
« Next Oldest | Next Newest »
Station List not showing any United Kingdom stations | dgoadby | 2 | 13,416 |
2019-04-15, 16:35 Last Post: dgoadby |
Removing Station 723 from list | Ian.Cooke | 5 | 30,221 |
2015-02-03, 20:39 Last Post: Toxic |
