#41
(2019-02-19, 22:34)dupreezd Wrote:
(2019-02-19, 21:45)Blitzfeuer Wrote:
(2019-02-19, 20:48)Egon Wrote: Dear Blitzfeuer,
station 1863 is not assigned to a user!
Insert the processor ID in the "Assign a new station: (Processor-ID)" field.
Egon
Dear Egon,
Every time I have inserted such as the station number "1863" it has immediately disappeared.
Mayhaps the "Processor-ID" is not the station number at all, but rather my "User ID"?
Or mayhaps an obscure number such as that of a CPU "processor ID"?
Confused, but still trying to understand...what specifically is the mysterious "processor ID?
Blitzfeuer
Blitzfeuer, go here http://en.blitzortung.org/login.php and logon.  Then assign a new station.
Regards
Dries
Hi Dries, thanks for the graphic -- it is something I have never seen before.  Even just now I logged in again using the DE-language link you gave me, and it just shows the info I have already unsuccessfully entered, with no view corresponding to your graphic.  So a "processor ID" is really a "device ID" without the dashes.  Great, but how does one get the view you graciously presented that applies to me, User 1546, station 1863 -- simply by logging in?  Huh
Stations: 1863
#42
Egon
Dear Egon,
Blitzfeuer
Regards
Dries
Log in to your controller (the one that you build) . Then on the Status page, about half way down, you will see the it.
Dries
#43
Egon
Dear Egon,
Blitzfeuer
Regards
Dries
I have done it for you!
/Egon
Stations: 2656, 3044
#44
1_i-mail.ru
2426
station not listed
Stations: 2354, 2426, 2439, 2440
#45
http://de.blitzortung.org/station_list.p...on_country=-
I can not confirm!
/Egon
#46
user name = phobia/1883
station number = 2428
region = Australia/New South Wales
station not in station list on either site & not 'participant' on forum
#47
We have not received any signal from the station yet. No region has been assigned yet because no position has been received yet.
/Egon
#48
(2019-04-18, 19:52)Egon Wrote: We have not received any signal from the station yet. No region has been assigned yet because no position has been received yet.
/Egon
Yeah, I’ve not got a GPS antenna yet. Can I get participant status on the forums for some assistance with antenna designs?
#49
AFAIK, the only way that anyone ever received participant status was after they started sending signals to the BT servers. Sorry.
A GPS antenna and an E-field probe should do that for you, provided that you have close enough strikes (the E-field probe is not sensitive enough to receive distant strikes). Otherwise, one or two 4-turn wire loops 1m in diameter should get you started as easily and inexpensively as is possible.
#50
Station not listed
User name: Zoran.Dragic
Station number: 727
User number: 623
Europe / Croatia
Stations: 727
#51
Hello
User Name for Forum: hazet
Station Number : 1355
Region: Europe, France
Station was listed before. Does not appear in the station list nor in the map.
Regards Hans
Mai 1st: No answer, no reaction, no explanation? Why? Is this a dead forum thread ?
Stations: 1355
#52
My station is now listed in two countries (Asia and Oceania), and i'm not a participant on the forums. Please help.
#53
... please try it again.
/Egon
#54
Hi!. I'm noticed 2 different links to my station 2224
I think that something went wrong...
https://www.lightningmaps.org/blitzortun...o_sid=2224
[Image: ALsz5d.png]
https://www.lightningmaps.org/blitzortun...n_id=15061
[Image: zPqYX2.png]
Best regards, Volodymyr
Lightning Volodymyr Lightning
Station: 2224
#55
This is really strange, unfortunately I have no idea why this is the case with this station, that can only be answered by Tobias.
/Egon
#56
To pile on, a screenshot of another strange database query result which occurs for a couple of weeks. Hope it can help the maintainers tracing database errors.
Cheers,
afram
Stations: 1592, 2279, 2845
#57
User Name for Forum: paul_harris77
Station Number: 2447
Region: Europe
Forum status not updated to Participant.
#58
(2019-05-12, 05:00)lyova Wrote: Hi!. I'm noticed 2 different links to my station 2224
Hi. I found a temporary solution to this problem is removing the station from the account and re-adding station.
At the same time, the station icon on the dynamic map disappeared and does not appear for a long time(
[Image: XimEJN.jpg]
But after a while everything returned as it was in addition my station disappeared from the search by country)
Station: 2224
#59
Your station is set to anonym, you can change it in the setting.
#60
(2019-05-14, 17:25)Egon Wrote: Your station is set to anonym, you can change it in the setting.
Thanks Egon this is my fault(
Station: 2224
  Station List not showing any United Kingdom stations dgoadby 2 13,431 2019-04-15, 16:35
Last Post: dgoadby
  Removing Station 723 from list Ian.Cooke 5 30,237 2015-02-03, 20:39
Last Post: Toxic
