LED placement question
Hi: almost finished with the build and no problems so far.
I have a question about the LED order. I know it really doesn't matter, but to be consistent with everyone else, which of the following is correct. I must add that I am somewhat red/green color blind: I can see a lit LED fine, but on a printed page...not so good.
On the front panel picture it appears as if this is the order is (starting L to R with Power)  R, G, G. Y, B, R, R
below that picture it shows the controller board with the order of R (on right of picture, would = Power on front panel), G, G, R, B, then whatever on the right of the front panel (Y,R or R,Y) . I know this is a silly question, but for consistencies sake, I thought it is worth it.
Steve
(2017-08-13, 16:10)SteveQlQ Wrote: Hi: almost finished with the build and no problems so far.
Steve
On my housing, I have R, G, G, Y, B, R, R. The only yellow LED is the Fault indicator.
Stations: 1955
Steve
Thanks, Joe..I thought the front panel picture would be the correct one, so since you confirmed my colors, I will finish using that.
Steve
(2017-08-13, 16:57)SteveQlQ Wrote: Thanks, Joe..I thought the front panel picture would be the correct one, so since you confirmed my colors, I will finish using that.
Steve
Awesome man! Let us know when you're online! Smile
Stations: 1955
Steve
For what it's worth there are LED chips on the main board and I thought they should match the case LEDs. The board chip LEDs are R G G R B R Y which makes more sense as the signal LED shouldn't be a fault indicator.
Stations: 1888
I wish I had read this before finishing my kit :-|
  Pre-Amp Placement StuartS 6 27,064 2019-06-11, 05:00
Last Post: Sleepypup
