System blue problem
Hi guys I have some problem with my system blue.
In admin control panel I have this message :
You need to Save to Flash and Reboot to take effect some of the new settings!
If I click on save button and reboot,  the system has the same message.
I have the 8.2 firmware.
Another problem is that the System blue often emits a long beep and the LAN LED disappears.
I have to turn it off and on again to unlock it.
Can you help me?
Thanks in advance
excuse for my bad English
Stations: 1583
(2016-11-29, 05:00)ohifra Wrote: You need to Save to Flash and Reboot to take effect some of the new settings!
That's strange. Is this still the case? Can you reproduce it?
(2016-11-29, 05:00)ohifra Wrote: Another problem is that the System blue often emits a long beep and the LAN LED disappears.
Unfortunately this is currently a common issue. Try to enable "Hide Hardfaults" under System menu.
Good morning, I solved the problem by connecting the detector with a LAN cable category 7 and after I set the LAN port in full duplex.
Stations: 1583
Lightbulb Fixed: Problem with System Green & Windows Tracker MuellerJ 1 11,504 2016-09-22, 19:03
Last Post: MuellerJ
